Author Topic: Electronics  (Read 4781 times)
Electronics
« on: March 27, 2009, 14:17:11 pm »
Stanley used led`s in the airgas-prosessor, but did he use them direct in the tube cells?.. i have read he had them optional in the patents but i am not sure...
I have tryed UV LED`s in a plate cell with no increase in splitting, but i will try IR LED`s insted.
Have anyone tested with infra red diodes in the 935-940nm range?...
Have attached an pdf. with a very cheap Ir led
Re: Electronics
« Reply #1 on: March 30, 2009, 19:18:36 pm »
don't discount the LEDs as not-working until the whole package comes together, you need high voltage, and pulsing, and the electron extraction circuit, what good is it if you bump the electrons off the water but leave them in the water bath? they just join up again, you need to remove them to make each atom into a positive ion, then all the positive ions will constantly repel each other, and not join up.
Re: Electronics
« Reply #3 on: August 03, 2009, 23:10:05 pm »
Re: Electronics
« Reply #4 on: September 26, 2009, 00:02:42 am »
Plasma ignition set for your HHO powered engine?
feature=sub
Re: Electronics
« Reply #5 on: September 26, 2009, 10:45:28 am »
feature=sub
Thanks, but i think i dont need such a strong spark, because my engine sparks normally pretty good. I dont see any advantages.
Re: Electronics
« Reply #6 on: September 26, 2009, 10:55:38 am »
I have to agree with stevie. It is possible that not everytime the hho will ignite, Most of the time it does though. We understand that hotter sparks can make things a bit more efficient, But in this case, Honestly,,, Its not worth the hassle and it is not a must by any means. Racing Bugs uses hotter sparks to go really fast hehe... If you can quickly throw a device to it, and it doesn't hurt your wallet.. I guess go for it.
Re: Electronics
« Reply #7 on: September 26, 2009, 14:09:52 pm »
My father is of that same opinion, "a small spark is enough to ignite, so most products like these is often a gimmick". But maybe this can solve the drowning problem that ordinary spark plugs have sometimes with big V8 carburetor motors. A wet sparkplug don`t work so you either need to wait for hours until they dryes or have to clean them one by one, but that is with petrol...
Haven't tryed with HHO yet, but maybe plugs get wet by water when the HHO is ignited in the cylinder?.. anyway i will find out soon.For my father got awesome technical skills, and now he want to help me with run a car on HHO!!!
