Author Topic: mikrocontroller code?  (Read 9574 times)
Re: mikrocontroller code?
« Reply #16 on: April 07, 2009, 15:54:38 pm »
Potential drop (difference) over L with DC when current is stationary: constant current * ohmic resistance.
Don't you agree?
Yes, wait, if only an inductor is connected directly on a 5v dc powersource, there is always 5v difference
illustration:
Pulsed LR circuit with T1 =T2 = tau, left is voltage over R right is voltage over L. Left have the same peak voltages, V/div aren't the same.
« Last Edit: April 07, 2009, 20:12:34 pm by Alan »
« Reply #17 on: April 07, 2009, 21:09:19 pm »
Don't you agree?
of course this is right for dc.
illustration:
is this ac or pulsed dc? anyway you can see how the voltage at the inductor is before the voltage at the resistor, if you'd watch the current it would be the same everywhere in the circuit.
« Reply #18 on: April 08, 2009, 12:53:13 pm »
i measured the properties of my tubes and got my capacitance calculated. for all 4 tubes it should be 0,63nF, with my l/c-meter i measured 1,00nF, so this could be right more or less. unfortunately i do not know how to calculate the parasitic capacity of my coil which would make the whole capacity larger.
another problem i do have with my coil: i measured 1,23µH for each one with my l/c-meter. but i calculated a capacitance of now 25µH for both in series. however i do not know the relative permitivitty of my ironpowder core, a table here says it's between 300 and 3000. taking the minimum of 300 leaves me with 7,6mH. Ohmic resistance of the coil and the wires to the cap is 2,6Ohms.
As a dielectric constant for water i take 77, the lowest value too. All my caps together should have ~50nF while filled with water.
L,C,R bring me to a resonant frequency of 3,2kHz, but again i do not know. The µr factor alone could change the frequency tremendously.
« Last Edit: April 08, 2009, 18:30:56 pm by haithar »
