Author Topic: Stan used AMPS, big time!  (Read 43076 times)
  • Yes I got Jolted,
Re: Stan used AMPS, big time!
« Reply #8 on: March 20, 2009, 21:31:41 pm »
Great.
I hope you can show us a video soon.
« Reply #9 on: March 20, 2009, 21:41:35 pm »
Great.
I am the inspirator , somebody will get inspired by this new knowledge , somebody here most likely .
When I am right , I know I am right , there can be no doubting me .
  • Yes I got Jolted,
« Reply #10 on: March 20, 2009, 22:15:32 pm »
Ok Dankie, Ok.
You doing a great Job inspiring.
« Reply #11 on: March 20, 2009, 22:45:49 pm »
Ok Dankie, Ok.
thx bro , I appreciate .
« Reply #12 on: March 20, 2009, 23:08:22 pm »
stan points out ways that its not a amp current causing the work.. but your on the right path by focusing on this perspective. he points it out for instance in one of his videos when hes talking about the hydrogen fracturing process. the electron extractor being a single high positve single tube with no neg .. being posistioned at  the exit port of electrical stress and laser energy on HFP.. it takes in the ejected electrons.into the circuit.. stan has a switching circuit that switched sedcondarys potential output between led(laser energy) and the choke. it is not a amp producer but a amp consumer.. the leds on time allows the electrons to flow threw them and consume them to produce photons.. so now you have a way to help rid the entering electrons entering positive choke without the power source having to do the work. and its making you another energy form that is needed.   copper is 29 electrons and 29 protons. emf displaces the electrons of atoms, when rectified it allows only one directional flow for them electrons.. now were creating difference in potential.. not osvillating electron difference in potential(like alternating current). so when you displace them atoms in the isolated chokes.. (isolated electrical stress air gap"air ionization".) the positive choke during high voltage probly has like 20 electrons and 29 protons per atom from the emf displacement.  by pullsed pumping action of one directional flow.  if positive has only 20 electrons  then the negative choke should have around 38 electrons and 29 protons.. thats a proportional difference which a isolated circuit should have... now if your electron extractor is hooked to a positive choke that has a displacement of about 9 electrons then it is a vacuum force on the electrons so it sucks them in.. but when they get sucked in it will throw your proportional difference off in your chokes.. it will cause the system to wanna produce current.. so they must be consumed.. what better way then to make it efficient.. you make it where your amp consumption is producing another energy form to make your system even more efficient hfp. this just hit me as i am typing.. i flashed to a dream i had last night .. and it just made me focus on the gas gun.. it has chokes on it.. so its chokes are not incorporated in vic 6-1.?????  the chokes are wrapped where the fuel gas passes through them before and after laser and electrical stress. think on that.
outlawstc
« Reply #13 on: March 20, 2009, 23:12:25 pm »
welp hydro that probably depends on how much quenching's  going on huh? since voltage wave guides act as a quenching circuit???
« Reply #14 on: March 20, 2009, 23:31:11 pm »
Hi,
I am a bit surprised by Dankie's reaction. First, we have to believe all whats written by Stan and now half of whats written by Stan is crap?
I do not have a problem with changing views on things, Dankie. No problem at all. ;)
@ Donald
In theory, we all hope to get some amps from the water. I know what Stan said, but i doubt his formula.
Till sofar i can confirm that I pulled a 10% of power out of the water, with my EEC circuit, compared to the input.
Not sure if we can get to the stage of 100V by 100amps.... Where did Stan get that idea?
Anybody?
@ Outlaw
Your explanation maybe something. However, my question on what that european Patent says stills wait for an answer.
Kinesis?
@ Electrojolt
Talk to you soon!
@All
The attached patent doesnt tell anything on using an EEC. It tells that the hydrogen generator used in that kind of setup is using amps and that the output of the alternator cannot compensate fully the power needed by the system....at least, in my point of view.
« Reply #15 on: March 20, 2009, 23:38:05 pm »
Considering all the progress made on the VIC lately, I don't see any point for this discussion, in a month or two we'll know for sure what's going on with this VIC Coil, since it is the heart of all the WFC technology.
I do think that you have to trust Stan if you really want to understand him and his technology. I've watched his videos at least 3-4 times each, and every time they make more and more sense. Stan explains things in the videos that are not in the Patents.
