Author Topic: alternator vic voltage burst sync pulse  (Read 12915 times)
« on: March 04, 2009, 09:49:15 am »
this topic will be of the alternator
Re: alternator vic voltage burst sync pulse
« Reply #1 on: March 04, 2009, 09:52:25 am »
notice the way the polarty are shown in tube cell drawing.. they are numbered 123123123123.. those represent each phases interaction with the cell and is really happening very fast. in up traveling motion.. here is an example of the sine waves again this time i added a sine showing there polarity and and off time. i just had to go over my research again me and kevin west are going over this right now. he though the alternator only put out i think 60 hertz no matter speer of the rotor.. wikipedia says a 6 pole alternator will put off 60 hertz at 1200 rpms. so rotor speed does fluxuate frequency.  the math goes like this for determining alternator frequency for the rpm speed..
lets say 1200 rpms.. we divide it by 60 seconds and get 20.. that means that each phase is putting of 20 hertz each.. 120 out from each other.. so with all three phases connected it gives 60hertz. but u gotta understand the vic sync pulse schematic is the frequency multiplier  notice the wave it makes compared the sine wave, it doubled. knowing that you must add one more calculation to your result 60... you gotta times it by 2 since it is a double freq. now we have 120 hertz at 1200rpms.. and its easier math to boot..5000 rpm is 500hertz,   6000 rpm is 600hertz and so on.
« Reply #2 on: March 04, 2009, 10:13:31 am »
Synchronous speeds
The output frequency of an alternator depends on the number of poles and the rotational speed. The speed corresponding to a particular frequency is called the synchronous speed for that frequency. This table [6] gives some examples:
Poles    RPM at 50 Hz    RPM at 60 Hz
2                      3000        3600
4                     1500        1800
6                     1000             1200
8                       750          900
10                       600          720
12                       500          600
14                      428.6           514.3
16                       375          450
18                       333.3          400
20                       300          360
More generally, one cycle of alternating current is produced each time a pair of field poles passes over a point on the stationary winding. The relation between speed and frequency is N = 120f / P , where f is the frequency in Hz (cycles per second). P is the number of poles (2,4,6...) and N is the rotational speed in revolutions per minute (RPM). Very old descriptions of alternating current systems sometimes give the frequency in terms of alternations per minute, counting each half-cycle as one alternation; so 12,000 alternations per minute corresponds to 100 Hz.
outlawstc
« Reply #3 on: March 04, 2009, 21:37:32 pm »
my latest post have been on the right path but still needed some kinks worked out.. when i started reading more into the voltage wave guide section i notice how stan was speaking of dynamics and static variables and oscillation. so it made me think what if he was using the alternators sequence to give it a mix of steam resosnat pulse and static.. it sounded logical for the oscillation.. but then i came across some other information that corrected that thought.
To ensure and maintain Capacitance Charging Effect (650) of Figure (7-4) across Water--
Gap (Cp) of (7-8) during applied pulsing operations (49a xxx 49n), Crossover Voltage Wave-Form
(780B) as to (780C) of Figure (8-2) is generally utilized by not allowing Convergent Point "Q" of
Figure (780B) to reach Electrical Ground Point (OV) when each Unipolar Voltage Pulse (Vpp) is
electrical energized in phase-distance relationship to cause the trailing edge (Vpb) of the first
Voltage-Pulse (Vppl) to meet the uprising leading edge (Vpa) of the second Voltage Pulse Wave
(Vpp2) at a distance above ground state (OV) determined by the Space-movement of the reforming
Voltage Peak Wave (Vppa xxx Vppn) within Voltage Pulse Width (TI), as illustrated in Rotary
Crossover Voltage Sync-Pulse Circuit (850) of Figure (8-11) where each VIC Pickup Coils (52A-
52B -52C) are axially spaced 120ยท apart to cause Convergent Point "Q" to be located 1/3 the height
of Voltage Amplitude Peak Level (Vpp),
Voltage Dynamics (220) of Figure (3-29) under the law of
physics which states "opposite electrical charges attracts",
Beyond amp restricting characteristic of said Amp Inhibiting Circuit (970) of Figure (10-1) as to
Voltage Intensifier Circuit (60) of Figure (3-22), the spiral-wrapped coils (Resonant Charging Chokes
56/62) being paired together, also, causes voltage level enhancement beyond applied voltage input since
the "Distributed Capacitance" (C1a xxx C1n - C2a xxx C2n) / "Distributed Inductance" (FL1a xxx FL1n
- FL2a xxx FL2n) of said "bifilar" wrapped coils (Figure 7-3) as to (990) of Figure (10-3) encourages
the compounding effect (increasing magnetic field-strength during each pulsing cycle) of
electromagnetic field-strength (Rp 1 a xxx Rp 1 n - Rp2a xxx Rp2n) (mutual induction) when applied
Pulse-Voltage frequency (49a xxx 49n) of Figure (334) passes through the positive energized Resonant
Charging Choke (56). Furthermore, the paired coil-wires opposite voltage potential [ positive electrical
attraction force (B+) - negative electrical attraction force (B-)] [ hereinafter called Electrical Stress (SS'
- RR') as to (160) of Figure (3-26)] are always equal in electrical magnitude/intensity since the wirelength
of each coil are the same. Pulse-Voltage repetition rate sets up the step-up charging effect Figure
(1-3) since the "Resonant Cavity" (Cp) functions as a "Capacitor" (ER) due to the dielectric value of the
liquid (or gases) which becomes an integral part of the VIC Circuit
so by using the 3 phases that are 120 out from each other  so now i can see the logic in by haveing both positive and negative pulse at the same amplitude it causes the law of attraction of like charges and force of deflection.
the static voltage would be Q the point at which each pulse overlap and meet.. im still looking further into clipped pulse
outlawstc
« Reply #4 on: March 05, 2009, 00:00:03 am »
Great work , keep working @ it , excited to see your evolution .
« Reply #5 on: March 05, 2009, 00:45:10 am »
HERE A VERSION OF 6-1 WITH SYNC PULSE
« Reply #6 on: March 05, 2009, 16:13:42 pm »
Outlaw. In the picture of the sine waves you posted , showing each phase. I have witnessed exactly this in my cell.It looks like a bunch of little magnetic feilds rising up out of the cell between the plates. As the cell is run it becomes more evident as to what is happening. I didnt realise what was happening untill you posted the picture of the sinewaves with each phase, Then I could see what was really happening in the cell. What I dont under stand is where this center tap is comimg off from the alternators stator.  I honestly believe your are on the right track in figuring this alternator schematic of Stans out. So  Let the knowledge that passeth all understand come forth.Thanks Much.
« Reply #7 on: March 05, 2009, 18:55:37 pm »
hi water,
.. you will need to get with dankie and get some stainless for the center tap... figure a alternator has 12 loops per phase on the stator.. check out waterforfuel.com and you can find some rewind kits.. or you can figure out how its done with some simple observation and u can buy your own wire and do it yourself.. the center tap is tapped in between loops 6 and 7 of each stator winding.. it splits the secondary in half.... i have a video explaning the center tap
i think it is there too.. i havent had a chance to replicate this yet.. all though once 6-1 is finished it will be a waste of time to make this unit.. since you can have the same thing without a rotary power source.... but im glad my drawing are giving a more vivd understanding to the workings of the elusive vic.
cheers
outlawstc
