Author Topic: Info  (Read 36781 times)
Re: Info
« Reply #48 on: March 25, 2009, 14:55:32 pm »
I wonder if SM wasnt playing with both kind of waves , Let John test with the same coventional method for now and keep this option open .
What if we just render the *atmosphere of our cell stuffy* like bearden says , change the ambient gravity , make things stuffy .
Re: Info
« Reply #49 on: March 25, 2009, 17:59:46 pm »
stanley meyer used normal wave inputs....but i have a feeling with the bifilar action and the stainless steel wire that it creates scalar waves that are given off......but ultimately the scalar waves are not used in the wfc cell.....they are just a biproduct of the vic coil as the coil spins the potential difference in opposite directions.....this would be an interesting thing to measure....we could surround it with a farrahday's cage and see if we can pick up an readings.
Re: Info
« Reply #50 on: March 25, 2009, 18:47:06 pm »
let me give scalar wave example from what im seeing.. compare it to a hurricane.. a hurricane is created by multiple differences.. tempature hot/cold, air pressure difference make winds flowing from high pressure to low pressure, and possibly electromagnetic waves ... when ever you get a swirl it is being caused by differential exchange.. 2 years ago when i was cheifing out a bong i noticed that as the air comes up the tube it swirls.. from that day i said that the swirl has to do with meaning and understanding.. little did i know that it would releate 2 years later lol. i think that swirl is being created from the exchange of vacuum potential which you are creating when you inhale and since theres a leak source of air coming from the bowl into the bong.. there is current that is being made visible by the smoke, and it swirls up the neck of the bong.. there are no cross winds in this bong to cause rotation..  just a vacuum force of the lungs which is traveling from your mouth into the bong and the up draft cause by the bowls intake.. those are the 2 forces causing the scalar smoke lol. for every action there a equal and opposite reaction..  means for every hole that goes right a electron goes left....
understand typical electric doesnt put things in unipolar states it oscillates electrons.  stan learned how to move electrons and learn that wire can poses pure positve potential when you strip alot of the electrons out.. then he learend how to displace them charges next to each other.. in a wire thats on the same core.. so for ever action theres a equal and opposite right.. so for one hole one way there 1 electron the other way.. now let that pump run.. soon you get a displacement by the 1000's thats when your volts are builing up..  but when they are being forced by the emf when there entering the choke they are equaly attracted to each other magneticaly.. the negative chokes aboundance in electrons is the exact amount the positve choke needs.. so they will sit in the wire next to each other in the core.. for the electron to want to cross the water  there needs to be an imbalance.. the voltage in the stainless wire is present mainly from the inductance charge of the secondarys.. 49a-49n throws the positve plate off balance? just a little so it is causing a potential shift to occur which is nothing more then dwell time and the signal?
outlawstc
Re: Info
« Reply #51 on: March 26, 2009, 07:23:04 am »
i got a kick out of that, especially when you said scalar smoke, hahaha
Re: Info
« Reply #52 on: March 26, 2009, 15:08:17 pm »
« Last Edit: March 26, 2009, 16:09:45 pm by Alan »
Re: Info
« Reply #53 on: March 26, 2009, 15:27:36 pm »
yea i thought it was pretty funny how i can realate somthing that would seem of no learning value in life to the usual observer and i was able to create a good lesson out of it lol. i tell you one thing.. weed is good! it opens the mind.. i used to be one of the most close minded people you would have ever met about 4 years ago.. what i dont get is why beer is legal and weed is illeagal.. beer in way more toxic to your body and it alters your mental state into a way more chaotic state then normal and  is a deppresant.. then you have weed.. somthing that opens the mind.. can releive stress and the most you can do on a overdose is take a good nap..?? beer will get you put behind bars because when someones drunk reality is irelevrent when it comes to consequences..
i want people to think on this.. this has to do with displacement of health and relating it to what we are learning..   ok you have a person that constantly eats fatty foods  mc donalds and what nots which are acid (negative) .. this person is 6 foot and 300 pounds.. to be a healthy 6 foot tall person. your most likely eating alkaline healthy foods and weigh around 200 pounds...would you believe that fat is like a build up of negative electrons on the body being stored? would you beleive that when your fat you have more force pushing down then lifting up??? nature has many answer waiting to be related to how everthing releates.. everything exsist do to forces.. and all forces have a opposite.. so theres allways a storm of the differences trying to meet and balance in life which is what paints the canvas.. a little deeper to what is happening in the body when eating fatty foods with bad fats (fatty acids).. when you consume to much of these bad foods your stomach is still absorbing it even if you dont need it.. lifes about balance and you just through your blood in your body into a rising acidic state.. if your ph goes over 7.6 or 7.8 you die.. so what your body does is it takes these over acumulated acids (negative charged) and store them as fat cells.. your actully capacitating without being able to discharge?  to repel off earth and be pulled toward space you must be more on the alkiline level.. but 7 is fine i think the blood trys to stay around 7.3.. it makes you feel awake and like your walking on clouds. its like alkiline opens your bodys channel to flow with earths and the suns powers?  i think the only reason people age faster is from haveing the down force pulling on them in a unequal difference from the up force. your skin starts to sag down like that force is making you melt back to earth lol. they say disease doesnt exist in a alkaline body... ok earth is positve charged if were repeling off it with positve force?     space must be negative charges since all the ozone exist by space( its attracting positves charged particles)  when somthin starts to build positve potential (holes)by removing electrons out of it, it will start to have attraction for space and repel from earth. so when somthin has light in it.. it can reflect!!!! positve= light= holes      and negative= electron  a photon is a elementry particle.. key word particle... so the more alkiline you are the more room you have for light!!!  it flow through us. theres alot said in this so please try to understand.
some of it could be off but most of its not.
Re: Info
« Reply #54 on: March 26, 2009, 18:31:01 pm »
i do about 5 ph test throughout my day.....i am almost always in 7.3-7.5.....if you go up to 7.6 your fine...yes there is alkalosis just as there is acidosis.....nutrition is my specialty...and if anyone wants to be healthier i would recommend  A COLON CLEANSE!!!!....most important thing in life to do......i have used dr natura's colonix.....and holy shit it is no joke of what comes out of you.....shit that has been stuck in there since you weren like 10 years old.......after that follow up with a liver cleanse.....but as for feeling like your walking on a cloud......i think a better way to put it is you have a true mental clarity.....but this isn't just from having alkaline blood......not at all.....you truly need to detox all heavy metals and built up scum.....you do feel elevated.
if we started a nutrtion section......i don't even know..........i am starting up a huge garden soon with compost piles and plant and fungi cultivations......the times are coming.......
so i find your reply very interesting.
Re: Info
« Reply #55 on: March 27, 2009, 13:50:18 pm »
tesla car theft protection system
http://www.flickr.com/photos/avi_abrams/1118238522/sizes/o/
http://www.darkroastedblend.com/2007/07/creepy-high-voltage-installations.html
from the days of soviet research
I didn't believe bearden on this, but this  makes ye think.
« Last Edit: March 27, 2009, 14:07:40 pm by Alan »
