Author Topic: Custum Alternator how to  (Read 15081 times)
hydro
Re: Custum Alternator how to
« Reply #24 on: April 03, 2008, 07:04:03 am »
when you go to make a post, when you are tying your post you will see a link that says additional Optopns, CLick on that, its just to the left of the post and preview buttons.
astuart
« Reply #25 on: April 03, 2008, 07:12:09 am »
ok got it.
here are the pics.
Tommy
« Reply #26 on: April 03, 2008, 07:16:31 am »
You have a 12 pole, 6 phase stator alternator. The 6-phase stator, with each phase placed 60° apart, reduces the amplitude of the current waveform. The 12-pole design also reduces the amplitude of the voltage and current waveforms. The combination of alternator frequency and multi-phasing reduces ripple and improves output harmonics.
The following page is probably not your specific alternator, but it does give all the information on pro's and con's of your type of alternator.
http://www.polarpowerinc.com/products/alternator/3500&6250alternator.htm
Hopefully that worked and it will help answer some questions.
hydro
« Reply #27 on: April 03, 2008, 08:05:48 am »
i had one of those and i chucked it in the garbadge, first i took a dremel and drilled out the 8 diodes, those diodes are high tech,, i think you have a mess but it can be used lol.. i wouldn't want to work with it. some late model fords are wired that way to.. i think the for rangers and escourts have those as well.
astuart
« Reply #28 on: April 03, 2008, 19:50:02 pm »
I thought this might be a 6 phase alternator.  I might clean this one up and see what it will do.  It doesn't have any other electronics built in and it has easy access to the rotor.  Both connections are in a plug in the back.  Has anyone tried one of these or would I be wasting time experimenting with something already tried?
