Author Topic: New theory.....the real one?  (Read 12135 times)
Re: New theory.....the real one?
« Reply #8 on: February 21, 2009, 21:19:23 pm »
Young Padawans , I am proud of you ;D
« Reply #9 on: February 21, 2009, 21:30:27 pm »
I have experienced that my platecell can light a 230V 60watt light bulp, after taking the power of the cel......
The first thought that came flying to me was Stanleys "Switchover circuit"
Must mean that he somehow switched between the cells...maybe there is a smart way to re-use the energy to another cell..
Best regards ;)
Good thinking! Should be part of the experiments!
steve
« Reply #10 on: February 21, 2009, 21:31:21 pm »
Hi,
After some study of the proces of Stan by many of you and me, i think that the HV theory is practically not proven (yet).
Care to explain what this was?
Hi,
Well, there is always a first for everything.
And here are the first bubles of a working HV water fracturing setup.
feature=user
Br
ps
sorry for the noice....
So in theory, you could could hook up multiple cells and not draw more current off the primary of the step up transformer?
Mikemongo
yes, you are right with that conclusion.
steve
You should ask Hydrocars/resonance king this question. He did that experiment.
« Reply #11 on: February 21, 2009, 22:54:16 pm »
its a good thought.. but i think his switchover circuit was mainly for the steam resonator..  it allows both side to be positve then negative switching rapidly causing a pumping/ friction action to the water kinda like a microwave..  and his rotary cross circuit with the eatra inductors just allow to to hit a high neg with the positive.. without it you only get a unipolar pulse leaving only.   the neg side is more of a neutral.. i guess a equal pos and neg pulse at the same time would be called a dipolar pulse.. hmm that energy form sounds familiar.. oh yea water is a dipole.. ac curent is never both at the same time.  i have been trying to understand that middle inductor for a while.. what does CT mean?
« Reply #12 on: February 21, 2009, 23:04:05 pm »
O yeah that switchover ?
WayTogo you are confused ... Thats bad for gas production
« Reply #13 on: February 22, 2009, 06:38:39 am »
Could it be possible that Stan was just giving the water a positive charge to the water , ( +h20 and not neutral) causing the water to give up electrons. Coated plates and hv,  I 've been considering a different set up for  a positive hv setup, just to see if  could be that simple, got nothing to loose.
« Reply #14 on: February 22, 2009, 16:42:40 pm »
stan says himself in videos that water is a dielectric liquid meaning it will take on electrical charge.. a high positive only will not work... it is called the water polarization process because it uses the negative to align all hydrogen sides with neg.. all oxy sides with the positive. when amps/ flowing electrons are involved it will mot work because the water will not line up uniformily to take on charge.
outlawstc
« Reply #15 on: February 22, 2009, 17:43:38 pm »
Here's something, diy 10kv dc generator, depending on the direction of the diodes it can do pos/ neg ions . So I thought why not build one of each and see what I can learn.    I http://www.uoguelph.ca/~antoon/circ/hv/hvdcgen/hvdcgen.html
