Author Topic: Dankies wire SPEC'S 430FR  (Read 3123 times)
« on: January 05, 2009, 02:04:16 am »
Measured wire: 220ML coating.
19.775 ohms per foot.
586.6 feet for 11.6kohms
Fluke meter 87, tested with 2 sets of leads to be sure.
Caliper width measurements:
.00585"
.148mm listed on wire spool.
Accurate.
« Last Edit: January 05, 2009, 20:11:36 pm by komtek »
Re: Dankies wire SPEC'S 430FR
« Reply #1 on: January 05, 2009, 02:09:56 am »
Great resistance ... It will be smaller than expected .
47,6 times more resistance then pure copper of same AWG.
This is a quote from the technician @ carpenter
Your wire was final strand annealed, making it squeakie-clean.  It should be ready for enameling.
Good luck.
Here is what carpenter has to say about 430FR , it seems we couldnt have a more perfect wire .
http://cartech.ides.com/datasheet.aspx?i=103&e=63&c=techart
« Last Edit: January 05, 2009, 02:30:00 am by Dankie »
« Reply #2 on: February 26, 2009, 00:02:39 am »
Nobodys ever posted on the solderability of the 430fr stainless wire.
It won't solder.
Have to make a screw terminal for contact.
