Author Topic: Its about time to start building on Ionization projects.  (Read 15140 times)
Re: Its about time to start building on Ionization projects.
« Reply #24 on: December 13, 2008, 12:30:02 pm »
I have used 5 volts ultra violet diodes direct in a hydrogen cell without any noticeable changes in gas production.
It only looks nicer, but i did not give any effect.. and F.... i bought 50 pcs. of them..  :-\
But i did not pulse the diodes.. maybe i should if someone can learn me to make a pulse circuit for the diodes?
« Reply #25 on: December 20, 2008, 10:45:31 am »
Hi,
I found a new weblink and picture that explains lots of the photon ionizing system!
http://www.gasmonitors.co.kr/techapp/pidtrain.htm
« Reply #27 on: December 20, 2008, 17:04:49 pm »
This is from the "Research Paper on Ravi’s Water Fuel cell Replication"
"Insertion of a laser into the resonance cavity
In Stanley Myers’ research papers, is the insertion of a laser into the cavity, injecting certain light frequencies into the cavity to assist in the fracturing process. This would be done by using a cell with cavity placements for high frequency light-emitting diodes in the area of 395 nm wave length. This cell would be conditioned, prepared and coils wound to suit. After the conditioning process the cell would be finally tested with light-emitting diodes."
I find this 395 nm wave lenght interesting.  That the black light used in forensics
« Reply #28 on: December 20, 2008, 17:37:52 pm »
Ravi papers are 100%  blasphemy  . That guy caused way to much damage , nobody talks aout him anymore because nobdy could ever replicate his cell .
People have concluded that he was disinfo .
« Reply #29 on: December 20, 2008, 17:57:46 pm »
This I quote,
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance ---- that principle is contempt prior to investigation."       ------ HERBERT SPENCER --------
« Reply #30 on: December 20, 2008, 20:15:59 pm »
You should ask around , many people have tried replicating his cell . As you may have noticed , nobody is talking about ravi anymore .
I think he had a post @ overunity.com
« Reply #31 on: December 20, 2008, 22:08:40 pm »
LightBulb here's the pdf on Ravi
PDF: http://www.panaceauniversity.org/Ravi%20Cell.pdf
