A clean and green environment is a human right
Home
Help
Login
Register
Ionizationx: a clean environment is a human right!
Projects by members
Projects by members
Kinesisfilms
(Moderator: Login to see usernames) »
unipolar pulse trains
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
Go Down
Author
Topic: unipolar pulse trains (Read 81485 times)
50+
Re: unipolar pulse trains
Reply #80 on:
November 19, 2008, 23:28:36 pm »
everything Meyers is not wound like neogen
Logged
Moderator
Hero member
Reply #81 on:
November 19, 2008, 23:43:54 pm »
yes it is.......there is only 1 and only ONE diagram where it is not wound like teslas, neogens, naudins, wests, and aaron m's..........and that one might be a mistake if anything......for there are over 10 showing the connection to be exactly like neogens........if you watch the new zealand lecture you will see he even says the forces have to be opposing each other in the inductors...to create a inductive resistance.........and then the inductor will work 250,000 greater then a normal inductor......i have done the tests........you will find out when you get an oscope.......
WOULD YOU HAVE A LOOK AT THIS EVERYONE ONE OF THESE PEOPLE CONNECT THERE BIFILAR THE SAME WAY......BUT YOU DANKIE SAY IT'S NOT THE SAME......DO YOU SEE IT NOW.....VISUALLY?......ONLY 1 SCHEMATIC SHOWS DIFFERENT IN THE ENTIRE TECH BRIEF......AND IT IS MOST LIKELY A QUICK "TYPO"
MEYERS OPPOSING
(http://i2.photobucket.com/albums/y2/kinesisfilms/ionizewaterinlet.jpg)
(http://i2.photobucket.com/albums/y2/kinesisfilms/orientationofvic.jpg)
NEOGENS
(http://i2.photobucket.com/albums/y2/kinesisfilms/neogen_bifilar_with_wfc_165.jpg)
WESTS
(http://i2.photobucket.com/albums/y2/kinesisfilms/WFFLRCcircuit.jpg)
AARON SHOWING THE DIFFERENCE
(http://i2.photobucket.com/albums/y2/kinesisfilms/wf_meyer_aaron_forum_coils1.jpg)
AARONS
(http://i2.photobucket.com/albums/y2/kinesisfilms/wf_meyer_aaron_video_meyer6.jpg)
NAUDIN
(http://i2.photobucket.com/albums/y2/kinesisfilms/wf_meyer_jh_bifilar_spiral_coil.gif)
TESLAS
(http://i2.photobucket.com/albums/y2/kinesisfilms/TeslaBifilar.png)
Logged
50+
Reply #82 on:
November 19, 2008, 23:49:19 pm »
Well im not too worried about this , as you said before its just a matter of connecting the other way it takes 2 seconds...
The bifilar in the international evaluation report is wound with opposed fields North south , North south
Logged
Moderator
Hero member
Reply #83 on:
November 20, 2008, 00:00:14 am »
one last thing!!!!! you find the resonating frequency of the choke...........then that frequency is factored into the RESONANCE OF THE LC CIRCUIT......THE BIFILAR CHOKE (L) AND THE WATER CAPACITOR (C)......NOW THE DIODE MAKES THIS NOT A RESONANT ACTION!!!! BUT I FINALLY UNDERSTAND WHY IT IS RESONATING!!!! GATTTTTTTIIINNNNNGGGGG.......FORCES THE CAPACITOR TO DISCHARGE RIGHT WHEN IT IS FULL......WHERE IN RESONANCE WITHOUT A DIODE IT WOULD NATURALLY DISCHARGE........WHEN THE CAPCITOR IS GATED OFF AND DISCHARGES THIS IS A MANUAL RESONANCE..........THIS CIRCUIT ACTUALY FUCKING WORKS!!!!!!! THE WAY IT IS DESCRIBED!!!! everything makes sense now!!!!! seriously go to a library and start from the beginning it makes everything understandable!!!!! meyers doesn't explain how it works but just tells you in a simple way what he did.......understand what he did!!!!! it makes this easy!!!! i am almost there.
Logged
2Curious4WFC
Guest
Reply #84 on:
November 20, 2008, 21:10:05 pm »
kinesisfilms,
great success story, congrats. Would you mind sharing, what the resonant frequency for your choke coil is ? kHz, Mhz ? And what your gating frequency is ? Hz, kHz, MHz ?
Is it audible on the tubes as well ?
Cheers
Logged
50+
Reply #85 on:
November 21, 2008, 05:12:39 am »
Kinesis it looks like you hit a sweet spot !
You are indeed getting close.
Logged
Administrator
Hero member
Reply #86 on:
November 21, 2008, 10:15:14 am »
Hi Kenisis,
You doing great!.
I can confirm that i had my bifcoil connected the same way as Aarons and Ravi.
That gave me the step-up charging wave.
Logged
Member
Reply #87 on:
November 21, 2008, 12:33:32 pm »
which gating are you talking about kiness :
programmabe variable gated pulse - voltage frequency T3
or
programmabe variable gated pulse frequency input T1, T2
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
Go Up
Projects by members
Projects by members
Kinesisfilms
