Author Topic: unipolar pulse trains  (Read 86819 times)
Re: unipolar pulse trains
« Reply #64 on: November 15, 2008, 06:46:11 am »
(http://i2.photobucket.com/albums/y2/kinesisfilms/charging.jpg)
« Reply #65 on: November 15, 2008, 07:05:20 am »
i have a suprise on its way.....
"resonant charging choke"
« Reply #66 on: November 16, 2008, 00:33:51 am »
as stated from the patent:
(http://i2.photobucket.com/albums/y2/kinesisfilms/resobook.jpg)
(http://i2.photobucket.com/albums/y2/kinesisfilms/electronicdictionary.jpg)
(http://i2.photobucket.com/albums/y2/kinesisfilms/electronicdictionarychoke.jpg)
and another side note...the wire of the choke must be quite tiny......or else capacitance of the choke at the chokes resonant frequency will be low......this has been tested.
I NEED A SPECTRUM ANALYZER NOW.
oh and if there are any terms that confuse you just let me know i have the book that stan got all his terms from......switching diode, unipolar pulse core, pulse transformer.
« Reply #67 on: November 16, 2008, 01:01:48 am »
Great post, Kinesisfilms!
steve
« Reply #68 on: November 16, 2008, 01:09:45 am »
i must admit , this is some great info .
« Reply #69 on: November 16, 2008, 18:48:58 pm »
Tesla's "COIL FOR ELECTRO MAGNETS," patent #512,340 is a very special coil design because, unlike an ordinary coil made by turning wire on a tube form, this one uses two wires laid next to each other on a form but with the end of the first one connected to the beginning of the second one. In this patent Tesla explains that the double coil will store many times the energy of a conventional coil. A bifilar coil is capable of holding more charge than a single wound coil. When operated at resonance, the distributed capacitance of the bifilar coil is able to overcome the counter - electromotive force (e.m.f.) normal to coils, inductive reactance. Because of the electrical activity, a bifilar coil does not work against itself and the potential across the coil quickly builds to a high value. The difference between the turns becomes great enough that the energy is practically all potential, at this point, the system becomes an electrostatic oscillator.
A standard coil of 1000 turns with a potential of 100 volts will have a difference of .1 volt between turns. A similar bifilar coil will have a potential of 50 volts between turns. Stored energy is a function of the square of the voltages the energy. That equates to 502/.12 = 2500/.01 = 250,000 times greater than the standard coil.
and there we have it......1 resonant frequency but 2 things in resoance.......this is of course not the single core setup but the transformer seperate from choke.......with a single core setup there would be multiple resonant frequencies, with each one favoring a certain coil.
ANY ONE KNOW WHERE TO GET A CHEAPCHEAPCHEAP SPECTRUM ANALYZER??
« Reply #70 on: November 16, 2008, 19:42:59 pm »
« Reply #71 on: November 18, 2008, 04:24:39 am »
alright well i guess my next investment is a spectrum analyzer......i need a visual reference.....i dont think the same resonant equation applies to a bifilar coil when trying to find the bifilar resonance.....not the vic resonance.......
see the bifilar is a resonant charging choke.....which means at the resonant frequency of the bifilar choke the distributed capacitance is at its perfect point........so now it's not just an inductor but a capacitor.......i then take that frequency which makes the charging choke resonate and figure the water fuel capacitors capacitance.......then we have our working system........but by just basic mathematics there are so many factors......and resonance of the choke being slightly off will not produce a pulse on the off pulse......AND THIS WAS THE PROBLEM THE ENTIRE TIME!!!!
LITERALLY THE WORDS RESONANT CHARGING CHOKE HOLD THE GOD DAMN SECRET TO MAKING THIS SHIT WORK........and since the the bifilar is hooked as tesla states in his patent but with the wfc in between we can now achieve 250,000 times greater distributed capacitance than a normal inductor........with tiny copper wire we can easily achieve the 10kv range............but for the 40kv range as used in the injectors stainless steel wire would be a great thing to have.......but i think that normal stainless steel wire will work seeing that the stated ss wire "which is ideal" is far to hard to come by.......we can make the entire thing out of copper but to achieve 40kv range at .0001 amps we need more resistance........and simply placing a resistor in line will not work........it has to have resistance while creating inductance at the same time.......i'm thinking a trip to an art store to find thin, coated, ss wire will be good enough......
I BELIEVE THIS IS IT EVERYTHING DOES LIE WITHIN THE BIFILAR CHOKE.......
if you have already built a bifilar choke look at teslas patent and the place where he connects A to B is where you place the water capacitor in between.
IF YOU HAPPEN TO HAVE A SPECTRUM ANALYZER AND AN ALREADY MADE BIFILAR COIL FIND THE RESONANCE OF IT WITH THE SPECTRUM ANALYZER (its highest peak) THEN USE THAT FREQUENCY FOR YOUR LRC NETWORK WITH THE CAPACITOR PALCED AS STATED ABOVE........THIS WILL PRODUCE A VERY HIGH VOLTAGE......BUT TO ACHIEVE EVEN HIGHER.....IT WILL TAKE A BETTER STEP UP TRANSFORMER AND RESISTIVE INDUCTIVE WIRE.
THIS IS WHAT SPECTRUM ANALYZERS DOOO!!
(http://i2.photobucket.com/albums/y2/kinesisfilms/brannontest44046.jpg)
RESONANCE!! OF ANYTHING AND EVERYTHING!
