Author Topic: The Water Fuel Injector: How he ran his car on water...  (Read 16676 times)
Fiditti
Re: The Water Fuel Injector: How he ran his car on water...
« Reply #8 on: October 16, 2008, 01:25:25 am »
Pulsed,
Very cool looking circuit.  Thanks for letting us see it.
It is very very exciting to have you with us.
Please let us here much more from you about this system of yours.  Thank you very much!!
You have great knowledge and we all want to learn from you.  We are your students.
Best Regards,
Fiditti
tester
« Reply #9 on: October 16, 2008, 14:02:32 pm »
Oh my please dont say that! ;)
We are all students of Meyers.
Here are some pictures of my replication of the steam generator...
Picture one is the range of items I am using.
Picture two is the Ioniser itself, real life version of the picture in the 6th post.
Picture three is how it is all fitted together.
At this moment in time I have not built WHAT I CALL THE STEAM RESONATOR (laser injector) because this is not the crux of the system.
the EEC too is not built yet and I am awaiting many parts.
once again I appologise.
You have nothing to be apologizing for. I apologize to you my friend.
Pulsed, what happened to the circuit i had drawn? It does look as if one of the diodes are improperly inserted on the filament. I cant stress this enough, look at how the primary of the auto ignition coil is wrapped, and why its called a condenser and not a capacitor. I've explained this to many users on msn as well but it took me much time. We have step by step videos here showing a coil being unwrapped.
You're making Great progress in what you're doing. I Feel that what you're doing should be done by someone. I agree that steam is a gas vapor thats very vulnerable, I also think it is part gas in some way, that it just needs the proper methods to extract like your researching now. I do thank you for letting us know what you're doing, "it looks amazing so far." About a week ago i was experimenting with steam also, i just don't have the time right now to setup lasers and build a system for condensing the steam, "i felt as if it was reforming as it exited the water." However i did catch it into a 2 liter bottle to have it collapse a short while later, that was neat. Yes, ionizing these atoms by giving the a polarity charge and extracting the electrons could leed to success. I have also learned that no flame can be sustained into this gas, it was my intentions to cool it then retry and note the effect. At that time i was determined to catch this gas and alter it. However i have other things that has to get assembled.
Unfortanitaly I now have this dune buggy engine i have to put together. Today i installed the crank and painted the housing. This will be my 3rd time of putting it together. I still recommend you to look at the post i referred you to, The coil in that circuit is very important to understand because the way it restricts amps on charge and increases voltage on discharge. Gotus used this same coil to violently ignite water. I look to update and use it on my buggy. I am glad to see that you haven't given up. Maybe soon i will be able to continue the vapor test as i feel it is coming.
  • Yes I got Jolted,
« Reply #10 on: October 16, 2008, 16:13:41 pm »
Hi Plasma,
That was me that metioned my experience with ionizing steam.
Welcome to this great forum.
tester
« Reply #11 on: October 17, 2008, 08:29:27 am »
I am in healthy contact with electrojolt, he is one of a kind.
« Reply #12 on: October 17, 2008, 18:15:21 pm »
Thank you pulsed for explaining your thoughts on Stans work!
Is there any practical example of your work that you can share here?
steve
Fiditti
« Reply #13 on: October 18, 2008, 02:37:01 am »
Pulsed,
We are so happy to have you here.  Please keep your great information comming to us.  Thank You so much!!
  • Yes I got Jolted,
« Reply #14 on: October 18, 2008, 05:51:11 am »
Pulsed,
Don't mind Dankie.. he means well, he just has poor choice of words sometimes.
but it is all good.
« Last Edit: October 20, 2008, 19:58:44 pm by electrojolt »
« Reply #15 on: October 18, 2008, 21:32:46 pm »
Lol it looks pretty complex...
What did you think of the patent i suggested ?
« Last Edit: October 19, 2008, 18:22:51 pm by stevie1001 »
