Author Topic: where to buy  (Read 17740 times)
Re: where to buy
« Reply #16 on: August 30, 2008, 03:23:08 am »
no im actually building hte step up transformer with this toroid i bought.....then i am getting a core and bifilar winding it on a 1 inch diameter rod.... i am just going exactly what it says here....
(http://i2.photobucket.com/albums/y2/kinesisfilms/stanmeyercoilsjpg.jpg)
Re: where to buy
« Reply #17 on: September 06, 2008, 23:26:49 pm »
i just recieved the toroidal core with the exact specifications as in the patent ^^^^ above image^^^...WOW i didn't realize it would be this tiny and now that i see the wire gauges i realize just how small this thing is.....100 turns of horribleness and 600 turns of hell....i need to find an automatic winder.
tester
Re: where to buy
« Reply #18 on: September 07, 2008, 05:39:51 am »
The primary is 200 turns, the choke is 100 turns, Formed on a 1 inch OD bar. The only time high voltage is read across the fuel cell is at the freq of water, however this has never been seen. I think stan was referring to the voltage before the choke and after the cell, there is HV there. EDIT, well let me just point this out, he was talking about before the choke and after the cell, read the first 10 pages of the tech brief, its in there somewhere!
It may be possible voltage will go up at the resonate freq of water, so find that Freq and see if the used parts is capable of hitting it. Hydrogen resonates in the microwave at 1.4 Ghz or 1420 Mhz, same thing, which is why i was looking into masers and lasers.
EDIT, stan also told you the freq he used if you read another page or to, i think it was like 10 Khz, but the chokes double the freq, so 20 Khz or something of that.
In the invention, the adjustable frequency generator (Figure 12) tunes into the resonant condition of the circuit including the water cell and the water therein. The generator has a frequency capability of 0-10 KHz in a typical 3.0 inch water capacitor formed of a 0.5 inch rod enclosed within a 0.75 inside diameter cylinder. At start up, in this example, current draw through the water cell will measure about 25 milliamp; however, when the circuit finds a tuned resonant condition, current drops to a 1-2 milliamp minimum leakage condition.
http://www.rexresearch.com/meyerhy/wo92.htm
tester
Re: where to buy
« Reply #19 on: September 07, 2008, 05:53:51 am »
the resonant cavity, conversion of about 5 gallons of water per hour into a fuel gas will occur on average. To increase the rate, multiple resonant cavities can be used and/or the surfaces of the water capacitor can be increased, however, the water capacitor cell is preferably small in scale. A typical water capacitor may be formed from a 0.5 inch in diameter stainless steel rod and a 0.75 inch inside diameter cylinder that together extend concentrically about 3.0 inches with respect to each other.
Shape and size of the resonant cavity may vary. Larger resonant cavities and higher rates of consumption of water in the conversion process require higher frequencies such as up to 50 KHz and above. The pulsing rate, to sustain such high rates of conversion must be correspondingly increased.
From the foregoing description of the preferred embodiment, other variations and modifications of the system disclosed will be evident to those of skill in the art.
,,, now why didn't stan just run his car on 1 tube? any ideals? i think im being a little skeptic! Just to be clear you understand, that little vic will consume 1 gallon of water every 12 minutes! so, is this hodoo or what? Stan also said it took him like,, 32? gallons to make that trip was it? OH, and you needed a bigger unit if installed on a truck.
So if a cell that small can consume 5 gallons a hour, why did he use that BIG 9 tube cell when he only used 32 gallons of water to make that entire trip? Now im a little confused!
I'm also confused to why he claimed 4.44444 amps to each tube cell in his Test of evaulation on page 60. You know, the page that states a 1 liter cavity  where  1 psi of hydroxy is = to 1 liter of gas lol, therfor he produced 7 liters a min, i am also confused to how he kept water in his fuel cell at that rate, this would mean each of the 9 tube cells would have to be producing 777.7 cc's of gas in 1 min, 12.95 cc's in one second.
I've looked into the EPG, The more pressure your fuel cell is under, that means the more magnetic the gas is! If you place a Magnetic north and south POLE magnet on the OUTPUT of the fuel cell, "When you release the gas under pressure threw the magnet" ,,,,, "The gas becomes magnetized." The more pressure upon release the more magnetic the gas.  The gas is released in any normal None magnetic tube that loops, like a torroide, the more pressure the more magnetic the gas in this loop, to where it eventually goes back to the cell threw a " CHECK VALVE " OR Y"S out of the cell to a hydrogen Torch TIP. Lots of very fine copper wire was used to creat voltage and amps, depending on how you wanted to wire it depended on what you got, volts or amps, but not both.
Later the Hydrogen Gas Circulation "pump" was replaced with a ACCELERATOR pump, which was a coil. The check valve was still used which meant that Hydrogen Accelerator PUMP was strong enough to have a strong enough PUSH on that magnetic gas to force it threw the check valve upon reintering into the tank for recyleation. If the pressure within the loop was to great, Nitrogen was added to the mix!!!!!
I speak about the EPG because it was on stans car, It confuses people, it looks seriouse! Now you know what the EPG does, so now when you look at the car and see a big tank on it you will have some sort of ideal to what it was used for, to generate electricity, not to run the car.
Does anyone have any ideals what is going on here?
Did you also miss the part where stan said he ran his car on the "BOILER PLATE CONFIGERATION", Where he said " ALL OF OUR FUEL CELLS OPERATE ON 180 DEGREE OUT OF PHASE. "
Job 42 5,6 and 7 http://basicenglishbible.com/job/42.htm
« Last Edit: September 07, 2008, 08:34:04 am by KillerRain »
tester
Re: where to buy
« Reply #20 on: September 07, 2008, 07:54:50 am »
Stan put many things in his patents, Whatever stan was doing to run that car, IF he was running it, its not in the patents. Did he run the car on water? i dont know. Did he start it on gas? Yes! watch the video on youtube if you dont believe me, The buggy video, hear him whisper? also at 3 minutes into the video he again repeats to stan when he bends down to look,, charlie says,, stan,,, there is no gas in there, we used it along time ago.
Something was going on, i always wondered how an air cooled engine produced heat in the winter. But that still doesn't answer everything. There are a few that thinks stan had extra hidden fuel cells, and there are those who thinks he was stretching the gas with some sorta atomic maser laser knowledge.
The way i see it, with stevies new fuel cell, if stans information doesn't get leaked soon, he will be history if stevies measurements are right, and i wouldn't be suprised if this website was shut down due to stevies amazing measurements. Lets see what happens from here..
I think stevie deserves a really really big pat on the back! His device will help this technology more than any device i've seen, i would be supprized if nasa dont pick up on this and start using it. You dont suppost to produce that amount of gas with 700 watts, Include your power loss, your source wattage and go from there. see what that brings us. I do understand that groups have been working on drycells for a very long time, but i think stevo has something "different," his doesn't use additives and produces a large amount of gas, for that the setup is special. But alot is to be credited here. But additives is besides our point. it took all to figure it out, and one to make it work without additives! Now thats by no way an easy or cheap task to tackle. So now you can stop wasting your money on what does not work, and get what you know works. Thank you for figuring this out for me as i know my next cell want be a wast of money. ;)
kinesisfilms, sorry for taking over your post while i vented, i do not know why dankie tried to stir you away from your device, very odd as i don't think he understands much about this technology. Anyways if you want to look into splitting water using the vic, or resonate Freq i would admire that! I may also continue on looking to split water with the resonate freq as well ;) I just do not feel as if this is what stan was doing based on all the red handed facts i've seen here an there over a very long time period. In no way am i bashing you or this thread. I just had to get that out in the open somehow someway and it just happend to fit right in this topic. Stan says one thing somewhere, then another somewhere else, man i just had to point this out. What are you suppost to believe? Maybe he did run it on water and this was his way of protecting his work? maybe he was a fraud. "We will never know!!!!!!!!" unless someone from the inside tells us!
with that said, if you was to find the real amazing resonate freq of water, based on what you've learned, and you did this using your understandings and you acomplished it. would you give the credit to stan? with out a doubt in your mind, would you say , YES stan cracked water using the resonate freq of water and voltage potential? If you was to prove this method to work, then does this mean stan was right, he really did bust water using the resonate freq? If you become obsessed and you do get this working, who did it? I do think this can cause you to find out how to really do this, and if it turns out that you do get this working, and you go back and do it with the freq stan said he used, then yay. but what if you get so smart you see that there is no freeking way he did it with that freq, would you then say stan made a typo, or maybe say he may have said the wrong freq to protect his work?
how is 1 to know anything. This is a scrood up technology lol, i better stop here.
Re: where to buy
« Reply #21 on: September 07, 2008, 23:47:52 pm »
sorry i meant to type 200 turns on the primary just a typo.....and as for the bible qoutes i don't know why you would bring those up those aren't anywhere related to anything.....if your trying to relate it to stans logo than this is the correct verse....a
(http://farm4.static.flickr.com/3180/2677372505_cc514a6a8c.jpg)
s for all your beliefs on what is truely going on believe what you want but im listening to alot of what stephen meyers has said about his brothers technology.....and now stephen is smarter much smarter than stan is....and for even stephen to say that his brothers technology was real and working means alot....we will just have to wait and see.....i have to build this then i will wind the bifilar coil...and im done.
tester
Re: where to buy
« Reply #22 on: September 08, 2008, 01:23:01 am »
Nothing to do with stans logo, i guess you have to read the entire chapter to understand what i was trying to say ;) ,Eliphaz did wrong, even though he was taking gods side he was still punished for what he said to job about god which was not true about god. Eliphaz was young and claimed that some one skilled in the art doesn't have more wisdom than the young that sit back and watched which was not skilled in the art.  Eliphaz felt as if he had wisdom, but job had more knowledge, where job spoke only the truth about god.
Job was angry with god, he demanded god come talk with him so he could confront him, job wanted to know why his life was cursed as he was an upright man, why the sinners got rewarded. What job spoken was the truth about god, gods cruel ways, rewarding the sinners the way he did, making sport of the upright.
Job just got fed up with god, this is when Eliphaz steped in to back god up as job was not talking very kindly about god. For the lack of wisdon Eliphaz had about god he could not understand what job was saying, he did not live what job lived, therefor he did not see what job seen in god.
Job told god like it was, he spoke the truth. For that he was rewarded with 2 times as much than he ever had, and his disease was lifted away. He died a happy life. Eliphaz which supported god supported him without knowledge, for that he was punished.
Re: where to buy
« Reply #23 on: September 08, 2008, 02:21:32 am »
now this is my last question regarding the creation of this transformer......i would just take a wire and wind the toroid.......now would the beginning of the the wire for the primary connect to the positive of the pwm and the end of the primary wire connect to the negative pwm connection, or vice versa depending on the clock or counter clockwise wire wrapping???.......this is an important brain barricade for me to overcome, thank you.
