Author Topic: Step up charging experiments  (Read 13082 times)
hydro
Re: Step up charging experiments
« Reply #8 on: July 19, 2008, 19:16:19 pm »
atleast if your going to be working with high voltage and a resistor, atleast know what your doing, look for voltage drops to gain more knowledge. its as easy as typing in google, voltage drop resistor
http://www.bcae1.com/resistrs.htm
also note, just because both wires is not used, this does not mean that there is 0 resistance, if this was so then you would not get arcs, so ambient air has resistance. Actually the resistance of air is very high.
« Reply #9 on: July 19, 2008, 22:03:44 pm »
blocking diode = de-Q-ing diode,
tank capacitor = wfc,
rotary firing rate = pulsing rate,
inductors = bifilar choke coils.
H2,
The TC in this circuit is one of the Bifcoil chokes?
« Reply #10 on: July 20, 2008, 12:20:30 pm »
H2,
That pdf is terrible to read! That will cost me days to consume! :)
steve
« Reply #11 on: July 20, 2008, 22:05:21 pm »
the spacing you talk about is so incredibly tiny...what amount of voltage would you think would break apart the water?......i just recently purchased 18 tubes outers are OD .75 inch, wall is .065..... inner tube is .5 inch wall of .035....my spacing is .185.....around 4.7mm.....is this far too much of a space... i am planning on pumping in around 20kv to 40kv.
« Reply #12 on: July 20, 2008, 22:52:11 pm »
Wow, thats an interesting experiment Kinesis!
I must say that i ll go with H2O at this moment...
But, go where no man has gone before...I like that ! ;)
  • Yes I got Jolted,
« Reply #13 on: July 20, 2008, 23:16:15 pm »
I don't know if any of you guys seen this:
hl=en&fs=1
Looks interesting.. self resonance!!
« Reply #14 on: July 20, 2008, 23:46:33 pm »
Hi wcg,
Nice find!
Are you gonna build one?
  • Yes I got Jolted,
« Reply #15 on: July 21, 2008, 02:19:32 am »
Yes, it can't hurt to try.
