Author Topic: Ohms law and the alternator  (Read 4042 times)
« on: July 08, 2008, 11:24:05 am »
« Last Edit: November 07, 2008, 10:38:28 am by enlightening »
hydro
Re: Ohms law and the alternator
« Reply #1 on: July 08, 2008, 13:17:03 pm »
where is your resistance coming from, what causes it, where is your conductance coming from? where is your resistance Not coming from. Can you Control your next cell?
don't rely on yourself to figure this one out, look around for help.
hydro
« Reply #2 on: July 08, 2008, 14:58:39 pm »
your resistance is not coming from the water, your conductance is.
A conductor is something you don't want to use while working around high voltage, use rubber to be safe.
« Reply #3 on: July 08, 2008, 16:30:12 pm »
Well I always thought of hydrocars and stevie as akin to batman  & robin, but I think instead of changing your name to solo it should be “THE RIDDLER”   lol
As I have mentioned before, I’m not an electrician so I am a bit slow in this area.
Resistance……..Conductance…….???
Googled conductance and it is linearly proportional to the combined effects of resistance, voltage and current….
I have already seen from my alternator trying to supply current to a low resistance cell low amps, the cell produced gas in isolated areas, not uniformly across all surface area. To help reduce resistance to the cell and encourage more gas production I then added extra jump leads to cell, this reduced the resistance and the amount of amps from the alternator..less gas !
Is resistance not created from everything that the current tries to travel through ?
where is it NOT coming from ????
can i control the cell....i what way?
james
Hydrocars is having a split personallity....... ;) ;)
Today he splitted again..... ;D
Riddler, if you wanna talk about it.....you know were to find me 8)
The discussion about OHMS is a good one.
Br
hydro
« Reply #4 on: July 08, 2008, 23:10:15 pm »
post a photo or link to your cell, whats your gap? whats your height? od etc,,, plates tubes? we will go from there..
« Reply #5 on: July 10, 2008, 11:09:22 am »
Water now becomes part
of the Voltage Intensifier Circuit in the form of "resistance" between electrical ground and pulsefrequency
positive-potential ... helping to prevent electron flow within the pulsing circuit
Meaning: try to keep resistance high?
The higher the resistance of water, the better?
All this in comby with higher volts?
arggggg
