Author Topic: SPIKE'S BURTHA CELL  (Read 27768 times)
  • OO-Rah!
Re: SPIKE'S BURTHA CELL
« Reply #72 on: August 03, 2008, 14:38:55 pm »
lapperl
I like the idea of the roll pins.
 I was thinking of screws,
And insetting the ends.
But the pins would be easier,
And I could still band it with my hose clamps   8)
Now , All I need a day stretcher, If anyone has an extra one  ;D
Thanks Again
Spike
« Reply #73 on: August 03, 2008, 17:10:08 pm »
Spike,
  On second thought, the roll pin would be kind of permanent and difficult to remove due to the fact that they are designed to be pushed through.  I think a pull dowel would be a better solution.  This way you can still disassemble it for servicing.
Lapperl
keithturtle
« Reply #74 on: August 08, 2008, 07:30:05 am »
Possibly some sort of tie-rod clamping assy.   Since the failure was pressure related and not a flashback, try and think how to strengthen the non-threaded joints.    Roll pins might weaken the adjacent material and would definitely leak if they went thru to the cavity.
External clamping pressure might be ugly, but tenable
Turtle, using tie rods http://s237.photobucket.com/albums/ff213/keithturtle/?action=view&current=visioncell001.jpg
  • OO-Rah!
« Reply #75 on: August 08, 2008, 11:06:23 am »
Turtle
It's definitely a thought.
I just wish I knew how the pressure was before it blew.
It might have been a good thing.
Spike
  • OO-Rah!
Re: SPIKE'S BURTHA CELL ( LOW AMP TEST)
« Reply #76 on: August 11, 2008, 07:41:34 am »
 ;D GOT MY CELL RUNNING  ;D
Today I tried a low amp test using Lye and KOH
Here are my results
LOW AMP TEST
400cc/MIN 1 LITER/150 SEC (1TBSPN LYE/ 1TBSPN KOH)
9.5 VDC
3.4 AMPS
32.3 WATTS
12.38 MIL/ MIN/ WATT
178.33% FARADAY
It.s nice to be testing again  ;D
Spike
« Reply #77 on: August 11, 2008, 10:10:56 am »
Again a big WOW!
Very good Spike!
You are having the best results i ever have seen.
I ll add them to my testresult excelsheet.
Question: What about using plain tapwater without additives on the same level of power. Can you try that one for me?
