I just finished my 21 tube fuel cell (only 11 tubes installed currently) and it is shorting out when dunked in the tap water resevoir but not shorting when dry on the counter, outside of the tap water tank?
I keep cooking my 100 bifilar wound inductors when i connect them between the D14 circuit and the WFC, however, I can connect the D14 circuit with inductor to a thermal peltier device or a 12V light bulb without any ill effect or overheating (light bulb shows the pulsing effect quite nicely).
If I then remove the D14 circuit and connect an automotive battery DIRECTLY to the WFC's"+" and "-" leads, Electrolysis happens instantly and vigorously, BUT the positive and negative connections from the battery cables touching the WFC leads start turning red hot from short circuiting!
Take the WFC back out of the water, let it dry, and viola....no shorting??? Why is the water shorting it out?
Any suggestions as to what may be wrong?
