A clean and green environment is a human right
Home
Help
Login
Register
Ionizationx: a clean environment is a human right!
Projects by members
Projects by members
Spike
(Moderator: Login to see usernames) »
SPIKES ALTERNATOR
Print
Pages:
1
Go Down
Author
Topic: SPIKES ALTERNATOR (Read 4421 times)
Member
OO-Rah!
SPIKES ALTERNATOR
on:
June 01, 2008, 02:25:46 am »
Help !!!!!
I got my new alternator
tested it
dissembled it
removed the regulator
wired the rotor brushes to a small power supply, Grounded the negative to the case.
put three wires from the stator to my amp gauge
Spike
Logged
Member
OO-Rah!
Re: SPIKES ALTERNATOR
Reply #1 on:
June 01, 2008, 02:26:36 am »
And I still have no power!!
Spike
Logged
Sr. member
Reply #2 on:
June 01, 2008, 03:41:48 am »
have u tested the AC volts before the ammeter?
Logged
Jr. member
Reply #3 on:
June 01, 2008, 04:11:21 am »
Where did you tap your stator at?
If you tapped it before the diode bridge, you will have AC output.
Also, did you remove the capacitor?
LapperL
Logged
hydro
Guest
Reply #4 on:
June 01, 2008, 08:02:25 am »
i would suggest testing your diode pack, test each diode.
Logged
Member
OO-Rah!
Reply #5 on:
June 01, 2008, 09:33:05 am »
I think i just wired it wrong. They called me in to work this afternoon, But I'll take it to my alternator guy, And have him show me were I screwed up. But I do appreciate the help.
Spike :'(
Logged
Print
Pages:
1
Go Up
Projects by members
Projects by members
Spike
SPIKES ALTERNATOR
