Author Topic: New information  (Read 1367 times)
Re: New information
« Reply #8 on: March 26, 2021, 19:40:23 pm »
I will give you a secret. The secret is if you remove the secondary high voltage coil you will be left with a isolation transformer that is center tapped because coil was removed. Now that is a very big secret all done on One core or else it will not work on separate cores. So basically what you have there is a isolation transformer but with a secondary intact is where the voltage is restricted or current or whatever it may be and there is some great change there there is some phenomenon as we know with the biffler and XYZ and the other antimatter coil. Be careful not to wrap your calls the wrong way or they could disappear. And reappear somewhere else.
Dont tell me that you are serious here....are you?
Re: New information
« Reply #9 on: March 26, 2021, 19:48:34 pm »
Very serious steve. Start at 10 khz, work down to 3 khz, which is where I blown my generator, then 40 khz, and then 120 to 200khz, and please take me serious when I say this take some sort of extra precaution to protect your generators when you raise the voltage from 12 to 24 or you will end up where I am at
Re: New information
« Reply #10 on: March 26, 2021, 19:53:50 pm »
so what did you do with the original secondairy coil?
Did you remove it from the vic?
Just use the two choke coils as secondairy, or wrap a bifilar coil and use it as a secondairy?
I am happy that you still try to uncover the vic, Brian!
Re: New information
« Reply #11 on: March 26, 2021, 19:53:50 pm »
I was using a shunt capacitor as well
Re: New information
« Reply #12 on: March 26, 2021, 20:26:18 pm »
You use the secondary
Re: New information
« Reply #13 on: March 26, 2021, 21:20:59 pm »
aha.ok.
Two transformers on 1 core.
A isolation transformer with a secondairy after the secondairy.... ;) ;) ;) ;) ;) ;) ;) ;) 8) 8) 8)
Re: New information
« Reply #14 on: March 27, 2021, 01:29:13 am »
It is all on One core, just like the Vic.
Re: New information
« Reply #15 on: March 27, 2021, 01:31:18 am »
Yes, you have all that correct, then I dropped in the secondary and got that secondary smoking hot.
