Author Topic: 304 stanless steel  (Read 753 times)
Re: 304 stanless steel
« Reply #8 on: January 29, 2021, 11:06:29 am »
Jim, most of the brown color in the cell comes from the dirt between the watermolecules....
At least, thats what i always had....
« Reply #9 on: January 29, 2021, 11:17:37 am »
Could someone please post photos of stans VIC, im especially interested in his chokes.
« Reply #10 on: January 29, 2021, 11:19:08 am »
I always used 304.
And i also tried 430....
I know that you Brian, used 316...
whice of the 3 has the highest resistance in ohms...
« Reply #11 on: January 29, 2021, 21:01:01 pm »
« Reply #12 on: January 30, 2021, 15:24:09 pm »
Back in 2007 i used 304 stainless in the Vertical Cluster Array units
« Reply #13 on: January 30, 2021, 16:05:02 pm »
Steve has a good point that dissolved impurities can contribute to discoloration. Stan even says
this in  the Environmental Tape The well water in southern Ohio
often has a high iron content but if  you were to run a demo unit with  for first time with distilled
water you still get discoloration form the slight corrosion of the  non stainless bolts that  Stan used as well
as corrosion if the stainless. The demo units I made used all stainless bolts or nylon (r) bolts, and when operated
 with water they still became discolored but more so the longer and more times one operated the unit
without changing the waiter but just replenishing the water to  keep the water level above the top of
the stainless tubes
