Author Topic: I Cracked it!!!!  (Read 5805 times)
  • Build it. Power it. Use it.
Re: I Cracked it!!!!
« Reply #48 on: May 16, 2020, 21:06:33 pm »
thanks guys
I will continue testing......
I think the best thing you could try would be to pulse the input to the driver, on and off.
« Reply #49 on: May 17, 2020, 09:43:11 am »
« Reply #50 on: May 17, 2020, 13:45:09 pm »
Brian, if i understand your video explanation, you hook up a squareware function generator positive output with one lead to that tiny bif coil and then from there is one wire going to the diodes and cell.
I am correct here?
« Reply #51 on: May 17, 2020, 15:05:23 pm »
Excellent video Brian.  Thanks for all the screen shots.
Here's some more math:
One Coulomb equals 6.24 X 10 .exp. 18
One mole equals 6.022 X 10 .exp. 23
Therefore, with one electron per molecule, there's roughly 100,000 Coulomb per kg of water, which is one liter.  So we need .01 ml of water to get one Coulomb of charge.
But shouldn't you put that coil in a Faraday cage, to rule out an antenna operation, before concluding it's ZPE?
At any rate, the coil produces a biphasic signal.  And so will my hairpin capacitor.  (Shown in reply #32 on page #5).
« Reply #52 on: May 17, 2020, 17:13:32 pm »
I am correct here?
yes, sinewave.
« Reply #53 on: May 17, 2020, 17:18:12 pm »
I'm not sure at this point, nothing done here is normal. You can see results without a coil it's just far weaker and takes longer. My cell is running all night, has a steady stream now. But it's still a barely visible stream. But it is a stream that's free. I want a faster generator. I can't test above 20Mhz but in running at 1.8 mhz at the moment.
« Reply #54 on: May 19, 2020, 06:57:03 am »
« Reply #55 on: May 20, 2020, 18:07:27 pm »
I'm aware that rotation is considered as being a property, rather than a movement.  But if something is rotating faster than the speed of light, individual points would still move faster than light and the rotating system would move outside of the universe.
That's not the key to antigravity.
« Last Edit: May 20, 2020, 18:36:27 pm by tektrical »
