Author Topic: I Cracked it!!!!  (Read 5763 times)
  • Build it. Power it. Use it.
Re: I Cracked it!!!!
« Reply #40 on: May 13, 2020, 23:37:42 pm »
The next question is......what to do next...
You might try using a cluster of parallel LEDs for each of the diodes.  A cheap flashlight has nine.  You could judge how bright they are, and see what effect the lower resistance has on the gas production.
« Reply #41 on: May 14, 2020, 13:52:49 pm »
Make it better! It's small scale, get some resonate coils in parallel, start tweaking. I haven't had a chance to look at the driver stevie used. The frequency may can be altered.
« Reply #42 on: May 14, 2020, 16:15:11 pm »
And, of course, make sure the bubbles are flammable, not just steam being liberated.
I'm starting to spend more time on this project, now that my understanding of the importance of the new circuit is increasing.
« Reply #43 on: May 14, 2020, 20:46:27 pm »
I tried to burn some bubles.
50 times nothing and then just one time a tiny pop....
Not sure what i am producing here...
Thanks, btw, for your suggestions..
« Reply #44 on: May 14, 2020, 20:51:02 pm »
I changed the leds for super fast diodes.
The results are the same.
Adding a coil or capacitors didnt improve.
So i doubled my secondairy coil in size.
That gave me higher voltages. Results in bubles a bit better.
But not really hho pops after ignition...
« Reply #45 on: May 14, 2020, 22:17:23 pm »
Laser pointer diodes, shining between the plates?
« Reply #46 on: May 16, 2020, 05:01:16 am »
3 6 9 Tesla, if you understood that, then you could hold the keys to the universe.
Stevie, Add a second Mini Tesla, While you are doing that, Also look for the eleventh harmonic.
Be sure the second Mini Tesla is not identical to the first, as your not looking to boost power, but to apply a second frequency to the water. When Coil 1 and Coil 2 is at the tuned frequencies the water will generate the Third harmonic on its own.
However, if one wanted to skip the above, Increase the size of the Tesla coil, Add a second Mini Tesla identical to the first using a seperate Isolated power source.
A tesla coil should be designed so that it could be Tuned, as so for the second. There will be an eleventh harmonic at every frequency. Which of those tuned frequencies does water react to? Well with my Mini tesla when I put my hand on the glas container, I could feel the water Thumping the Container as if it was Pulsating in a way it could Bust the glass. Try feeling its heart beat on the external part of the glas stevie. Put your hands on it and feel it pumping the glass jar.
« Reply #47 on: May 16, 2020, 20:21:22 pm »
thanks guys
I will continue testing......
