Author Topic: I Cracked it!!!!  (Read 5099 times)
  • Build it. Power it. Use it.
Re: I Cracked it!!!!
« Reply #24 on: May 03, 2020, 02:37:26 am »
Radiant energy Steve. I'm working threw resonance and Tesla's building resonator is related, I'm surprised what can be done with just 1.5 volts at the moment. I'm in deep research at this time. I will share all my findings.
I can't wait to see someone confirm this above circuit.
I don't think the circuit has to be confirmed; it's basically an energy harvesting circuit with Stan's inductor added in.  But I am working on it.  What I'll try is one wire from a CFL.
https://www.google.com/search?q=energy%20harvesting%20circuit%20schematic&tbm=isch&tbs=rimg%3ACTeg3kEWk9vNIkA1AVOWongdwJWf69n6mhmW0i0-NLNnC3J2roxcvMy3eHh6Wf1tQW-gr684-SMLaSbiqkSdWOBVNvAYyEaXJ1akKhIJNQFTlqJ4HcAROL3DbHvMvGYqEgmVn-vZ-poZlhHp3AAVUHTkhCoSCdItPjSzZwtyEY0A7VZpteKJKhIJdq6MXLzMt3gRjEalN3_1s5zsqEgl4eln9bUFvoBF5dzDQphe9LSoSCa-vOPkjC2kmEbrlIae4jymuKhIJ4qpEnVjgVTYRjEalN3_1s5zsqEgnwGMhGlydWpBF5FlxxoEA6eGFlq9z-ygC07w&client=ms-android-verizon&hl=en&ved=0CBIQuIIBahcKEwi4ms-ktZbpAhUAAAAAHQAAAAAQCQ&biw=360&bih=511#imgrc=cPEsO9LMyspFzM,,
« Last Edit: May 03, 2020, 05:47:28 am by tektrical »
« Reply #25 on: May 04, 2020, 02:57:35 am »
Awesome!!!
« Reply #26 on: May 04, 2020, 03:02:31 am »
Awesome!!!
I think the best part, besides getting the bubbles, is that you discovered LEDs work as high frequency diodes.  I wonder if the circuit can be powered with rf from an antenna.
« Reply #27 on: May 04, 2020, 20:08:45 pm »
I collected some parts for replication  Brian.
Soon i must be able to smack it together... ;)
« Reply #28 on: May 06, 2020, 23:13:45 pm »
Look closely at that fets data sheet I used, it seems to work best. And that's cool on the led part tektrical! I can't wait to see you guys better this.
« Reply #29 on: May 10, 2020, 00:58:36 am »
My first attempt failed with getting a mini tesla circuit working...
Maybe my transistors are no good or my secondairy coil....
Monday i can get me some transistors....
The one i used sofar:
Ksp44
C945
Primary coil is 3 winding
Resistor 22k
« Reply #30 on: May 10, 2020, 04:40:00 am »
1m resister between gate and source/ground. May have to touch resister at gate as you increase voltage. Let go when leds light up. Do not over ramp the voltage until you become experienced at this circuit. Let run with leds lift for 10 mins or so. If no production swap cell polarity.
« Reply #31 on: May 10, 2020, 22:22:53 pm »
Jippyjee
The tiny transistor gets hot....
The lightbulb gets on
So, at least a babystep has been taken.
This tiny tesla does not visually ionize the air, but the gas bulb shows a radiant field of energy!
Now i have to find more leds and a heavier npn...
Cheers Brian!
