Author Topic: I Cracked it!!!!  (Read 7923 times)
I Cracked it!!!!
« on: April 22, 2020, 10:05:33 am »
I'm Proud to say I cracked it all! No, I dont give one damn shit about any credit, Im just glad this shit is finally over with!!! I've been researching this technology between tesla and stan for 25 years or more.
I was going to make a youtube video because I did want the views, not sure how that pay tube junk works and Im limited on time being I can only test on the weekends.
I will leave you with this grain of salt, for one, Because what I'm about to leave you with is all you need to know. So here be the small sentances.
I used a Step up coil from a Central Heating and air unit, (The Gas Furnace Igniter) All furnaces doesn't have them. The secondary measured around 1k ohms. I used the Telsa Mini Circuit on the net that containes just 1 resistor, 22k, I used a 2A224J Capacitor between the Source and Drain of the IRF740, Any N channel mosfet should do.
Heres where it gets tricky, You use 2 diodes and connect them to the output of the transformer, (Led Light emitting Diodes work best) Connect one opposite than the other. Now you should have 2 unconnected Ends. (That goes to your fuel Cell). HOWEVER, the (Contactor switch) from a Heating and Air Unit, (COIL ONLY NO METAL CORE) shall be placed between a Single round Tube Cell about 2 inches tall or so and one of the Diodes. I did this on the Negative side. This Circuit is Dangerous!
Thats all, you can produce hydrogen with only 1 wire folks, Thats right (A OPEN CIRCUIT) Produces hydrogen.
Unfortanately, Mosfets cant handle whats needed to be done here, Tubes will have to be used later, Thats another day for me. Everytime I start getting good production The fet Blows due to the back emf getting to high. Also, you will not be able to touch the leades of the fuel cell, I had a arc go threw my finger and it burnt a hole in the end of my finger. These are Radio Frequencys so you dont get shocked anymore, you get FRIED!! You will smell your skin smoking and the room will be filled with Smoke from your finger, this damage only takes a Nano second so you cant avoid it, this circit is nothing to play with.
Also, I will leave you with this un needed information. Telsa make Electric moters, they was 1 2 3 and so HORSEPOWER. I will say this another way because my time is limited here, 1 Horse can Pull 8k Pounds, so this means 2 horses can Pull, yup, you guessed it, 40 Thousand Pounds or close to it! So yes, Tesla's HP Moters, I mean, Energy Converters are like that!
Tesla Used 2 coils to power his Ac Generators not 1, Tesla Knew about horses, he used a Symbolic 2 Horse Coil ( 3 to 4 times its Load) to puse it into a Ring of (Sets of coils) ontop of Sets of More Coils) to step Electricity around in ways that is not seen to man on this earth as this information is public but not understood. Anways, thats not really important, What is Important is you understand and learn how to connect an ac Output wires To itself and make it run on 1 wire!
I will say this one last time before I go, that water Fuel cell is a (OPEN CIRCUIT) , Thats how it runs, I Gaurantee you this is a fact, I Put it on my life!! I say this because I know for a fact because I have been producting hydrogen this way for sometime now. Do Expect me to come back and reply to this forum or dont expect me to answer any question at all, because it may be weeks or moths before I log back in to this site.
Just so you understand, 1 wire goes to 2 connecting diodes, the unconnected ends of the diodes go to a fuel cell with a coil their between with an (AIR CORE) and Leds are used for the Diodes, I tested this setup with stanleys diode and it would not work. and again, this Circuit is dangerouse!
I used a Vacriac as the power source, and I Rectified that, and used 2 big capacitors to smooth everthing out. Build the circuit, raise the voltage! And get ready to blow some fets! I've blown a ton on this, and if you think the fet is blown, dont be so fast about replacting it, Turn up the voltage High, High enough to make the fet revive itself. You will eventually learn the circuit works and that Fets are no good, then you will get excited about what your doing and start looking for new ways other than fets.
Your cell phones will not work with this circuit running, your laptop will malfunction. Funny things around the house will start to happen. This is No Joke. Good day!
  • Build it. Power it. Use it.
Re: I Cracked it!!!!
« Reply #1 on: April 23, 2020, 17:49:55 pm »
This all sounds pretty good, but I don't understand the "single wire" part of it.  Two diodes connected to the cell, one with a series inductor?  Where's the open circuit?  Are BOTH diodes hooked to the same transformer wire?  If so, how is that the negative side?  Is there a rectifier?
« Reply #2 on: April 23, 2020, 22:56:45 pm »
I will make a second post. With a video, then I ask you to share with as many people possible.
« Reply #3 on: April 24, 2020, 00:25:58 am »
I'm starting to get a handle on this.  Both diodes are connected to the same transformer wire, with the diodes in reverse polarity and the other transformer wire left open.  The inductor is connected to the diode with negative polarity and the inductor's output is connected to the water cell, along with the other diode.  The transformer isn't rectified, or fully loaded.
This is an innovative approach to the single wire circuit.  Normally, both transformer wires are connected to a spark gap with an adjacent single wire electrode's circuit terminating on a polar mass.  (Which in this case would be the water cell).  With both approaches, the current flows up one side of the wire and back down the other side of the same wire.  At high frequency, these bidirectional currents are simultaneous.  Using the two diodes allows it to work with just one side of the supply, which is otherwise unloaded.
In my opinion this is a significant discovery.
« Reply #4 on: April 24, 2020, 08:37:17 am »
Quote from: Login to see usernames
Thst sounds promising, Brian.
I cannot wait to see yr video on this.
Well done!
« Reply #5 on: April 24, 2020, 10:19:58 am »
feature=emb_logo
« Reply #6 on: April 24, 2020, 11:18:03 am »
« Reply #7 on: April 25, 2020, 00:34:39 am »
It looks to me as another fantasy...
"Extraordinary claims require extraordinary evidence"
I think it's time to show it working the way you said it does, without "free energy tricks".
