Author Topic: Electron Extraction circuit  (Read 7857 times)
« on: May 22, 2008, 02:29:18 am »
(http://i.ytimg.com/vi/5W1bQkvvU3E/2.jpg)
Re: Electron Extraction circuit
« Reply #1 on: May 22, 2008, 08:53:01 am »
very unclear video, CN
An EEC must be setup like this:
1 set of 2 tubes for creating Hydroxy
On top of them with more then 0,5 inch space another set of 2 tubes.
If you use 1 tube for eec, then you  need the ground of the producing tubes and you will not extract electron for the water, but from your input circuit.
So, the EEC must be a floating circuit!
« Reply #2 on: May 22, 2008, 19:12:54 pm »
Thanks Stevie!
I did notice I had to share the ground...
« Reply #3 on: May 23, 2008, 00:49:30 am »
Heres a new update vid:
(http://i.ytimg.com/vi/hABBWO71zOo/2.jpg)
« Reply #4 on: May 23, 2008, 00:49:54 am »
A SS screen mesh will do the trick also.
How would you go on about hooking that up?
  • Pochin Hydrogen
  • Hydrogen to Drive
    • PochinTwin Hydrogen
« Reply #5 on: May 23, 2008, 08:32:52 am »
The same way Dr. Dingel shows in some of his videos. At the top of the resonance cavities attached from end to end inside of the cantainor.
Do youy have a link to that video?
mrgalleria
« Reply #6 on: May 23, 2008, 11:05:18 am »
Aloha,
Wouldn't it be good to use two dis-similar metals?
Like aluminum and copper, etc.
Bill
« Reply #7 on: May 23, 2008, 15:08:23 pm »
Aloha,
Bill
Maybe yes, but SS is higly resistance against corrosion and is cheaper like platinum...
Copper will be gone in 1 hour........
steve
