Author Topic: mrgalleria's WFC's  (Read 2707 times)
mrgalleria
mrgalleria's WFC's
« on: May 17, 2008, 03:43:45 am »
Aloha,
This cell consists of 7 sets of 304 ss, 24" long. Outside tube is 1 1/4" outside with 1/16" thick wall, inside is 1" with 1/8" thick walls. Inner tubes centers are sealed with plastic plugs gooped in place. Outer tubes exteriors are sealed to container walls with plastic and goop.
Water in cell is pumped thorough by a 2 amp SW fuel pump, and only flows thorough the ss tube electrolisis surface area.
Output volume currently untested. A second container holds the water as a reservoir.
Bill
mrgalleria
Re: mrgalleria's WFC's
« Reply #1 on: May 17, 2008, 04:02:07 am »
Aloha,
Here is set-up with reservoir, pump, and 6- 11" 304 tubes for a smaller version.
Also an experimental alt. mod and simple 556 frequency gen.
The alt. rotor has a section 1/2" wide notched on each half or side. The depth is about 1/64". Plan to fill notch with JB quick weld (non-conductive). Untested.
Bill
« Last Edit: May 17, 2008, 23:38:35 pm by mrgalleria »
mrgalleria
« Reply #2 on: May 17, 2008, 04:05:11 am »
Aloha, sorry, here's the circuit.
Bill
  • OO-Rah!
« Reply #3 on: May 17, 2008, 08:06:28 am »
looks good
can't wait for your next update
Spike
h2opower
« Reply #4 on: May 23, 2008, 22:59:23 pm »
Looks very nice indeed.
Now that college is out maybe I will do the math for the hho reaction with water mist/vapor expansion absorbing the heat of the hho reaction. Someone let me know if that has been done already.
