Author Topic: Poor man's unified field theory  (Read 1839 times)
Re: Poor man's unified field theory
« Reply #16 on: August 22, 2020, 23:29:38 pm »
Search for hooper's electrogravity research   , ofcourse he mistaken this force for gravity because this force cannot be shielded but the experiments he did on the motional electric field were true , this was cambridge 1940 little bit after relativity theory, what he measured was that when the magnetic flux moves it produces a lorrentz force, the lorrentz force is the relative speed of the magnetic flux to the charge so it's not only F = q v x B but F = q v x B + B v x q , by using this equation you can solve the faraday disk paradox properly, there are two magnetic flux forces for a charge on the disk . you can only get measurable voltage on the disk when you cancel the second term of the modified lorrentz law because that's when the force vectors (directions) are constant. The speed of charges in a conductor is very slow that's why the resulting motional electric field force is very low to be easily measurable but the speed of a free charge is higher so the force resulting from a spark will be higher.
http://www.rexresearch.com/hooper/horizon.html
« Last Edit: August 23, 2020, 14:39:03 pm by geon »
« Reply #17 on: September 13, 2020, 23:00:31 pm »
here is a scribble to understand this very basic "hidden" force , it translates to all electric phenomena and because the speed of electrons inside metal conductors is close to zero this force is tiny due to wires but it's big when talking about sparks because the speed of electrons is very large in sparks , it also coincide with the way sparks evolve, after some kilovolts sparks behave differently because of this force getting bigger than coulomb force so the total force changes signs , ofcourse you have to put relative speeds in, this is a relativity phenomena and the second term needs to account for a stationary observer on the stationary electron
https://imgur.com/a/js57EnW
« Last Edit: September 13, 2020, 23:19:45 pm by geon »
« Reply #18 on: September 16, 2020, 01:40:35 am »
This force is actually the electric field, just take the magnetic flux to be rotating in an electron and you get the coulomb force from the modified lorentz law. But how does the magnetic flux exceeds the speed of light when it's rotating? ( No a magnet doesn't rotate the magnetic flux because the dipoles which create the flux are set in place by neighboring dipoles ) It's because the magnetic flux isn't real, it's interference from the matter waves which make up the particles, you only need to use the superposition of two quantum states and expand the schroedingers equations to matter waves instead of probability waves, the probability is because of the energy content of the matter waves so there's is no conflict with current theory the probability current still exists as a function of energy. Any two quantum states can make up a particle, the  magnetic field manifests itself in the interference pattern because of relativity theory, the waves contract or expand according to relative velocity. if there was one particle in the universe no EM forces would exist. Gravity, magnetism , electricity are because of spatial deformations of the spacetime continuum .
