Author Topic: FULL ATTENTION TO ALL MEMBERS - MUST READ  (Read 1959 times)
« on: October 04, 2019, 01:23:00 am »
I have Instructions STEP BY STEP how the Vic works. The Instructions was written By Stan Meyer Himself!
I have a Parts List that goes with stans Instructions, Written Also by Stan Himself!
I have been filling this order, and also, I have covered all the areas that everyone has missed using all of stans instructions.
This Technology is very real! It has become very clear stan was not a fraud after what all I have found. Stan uses a Polarazation Process to cause an electron depletion that causes the covalent bod to be broken. It is very clear that 20 thousand volts can easily be read directly across the Exciter Arrays when you use the Voltage Depletion Process. FurtherMore, A Lazer, or a Led will further increase the process in the water to gas version to increase the rate at which the polarization process takes effect.
Furthermore, the Electron Extraction Process Destroys the electron in the Gas causing it to become Thermal Explosive energy.
Furthermore, Stored Liquid Hydrogen containing atomic altered Atoms in one tank, and the same in the oxygen tank.
Furthermore, It is very clear Stan ran engines on water before the VIC was ever invented. It is also very clear stan used a method called the Airiator to aid.
YOU GUYS SHOULD UNDERSTAND, IT DOES NOT TAKE ANYWHERE NEAR 12 LITERS A MINUTE TO RUN A ENGINE ON WATER, YOU HAD IT IN THE PALM OF YOUR HANDS, YOU DIDN'T DIDNT KNOW WHAT YOU WAS DOING.
I HAVE ALL THE INSTRUCTIONS.
I do not want to do this alone, who wants to take this project on?
who wants to get this technology out there once and forall.
Re: FULL ATTENTION TO ALL MEMBERS - MUST READ
« Reply #1 on: October 04, 2019, 01:55:11 am »
i want
can you send me by email ... sebosfato@gmail.com
12 L/m of gas is not so small quantity
55 amps gives 36 liters of  hho that is around 0,51 liter per minute of gas would generate 2 grams of hydrogem per hour + 16g of oxygem  120 watts is fair enough for a good cell and feed circuit
it could be generated with 11 cells in series having 5 amps to flow...
12l/m would need around 1320 amps or 11 cells in series having 120 amps flow i guess 3kw would do it
you got my attention.. waiting for it!
« Last Edit: October 04, 2019, 07:58:33 am by sebosfato »
« Reply #2 on: October 04, 2019, 08:02:31 am »
me too
« Reply #3 on: October 04, 2019, 14:20:53 pm »
"In the early days Stan ran a Bolen tractor at the Hughes farm but Stan would need to run the tractor a while before
taking it out in the fields on the farm. Sometimes he didn't have enough to get back to the barn.  He was using a
vessel with stainless tube in it."   I don't believe he was using a VIC at this time but more likely brute hydrolysis
and storage of the gas at that time
Are you saying that you have an original parts list written by Stan or a instruction guide actually written by Stan
from lab notes or such?   Or is this a guide written by you.......
« Last Edit: October 04, 2019, 17:02:59 pm by jim miller »
« Reply #4 on: October 04, 2019, 20:18:24 pm »
It's all stans writing. I will update the forum asap. And yes, he ran engines from water before the Vic.
« Reply #5 on: October 04, 2019, 22:27:28 pm »
where did you put? asap? is in your project section?
« Reply #6 on: October 04, 2019, 23:35:02 pm »
Are you kidding me? You have info strait from Stan and you didnt share it, sofar?
I am not sure if i must be happy or very sad....
« Reply #7 on: October 05, 2019, 13:55:48 pm »
Today is saturday, i see no better time than now to share it  ;D
anxious to see what your talking about.
