Author Topic: Plate cell construction tips  (Read 5750 times)
keithturtle
« on: October 29, 2007, 07:01:55 am »
The turtle has built three differing plate cell configurations, the difference found in the means of attaching and spacing plates.
As time goes on I will post those specific projects in detail to share the plus and minus qualites of each.
For now, drop by the photobucket
http://s237.photobucket.com/albums/ff213/keithturtle/
to see what's there.   I ain't got the bucket organised the way it needs, but that too, in time.
If anyone has a spare clock to send me, I've found something better than anti-depressants...
Take said ticking clock (it needs to be a working clock), place on an anvil, and swing a 12 pound sledge with vociferous determination, aiming for the center...
WOW...
Man, I feel better already!
Timeless Turtle
Re: Plate cell construction tips
« Reply #1 on: October 29, 2007, 15:43:14 pm »
Thats a very helpfull tip, my friend Turtle.... ;D
Keep on crushing the time!
keithturtle
« Reply #2 on: November 22, 2007, 03:35:21 am »
Another plate cell design has emerged from the pond muck.
Acrylic slab sides, 61 plates 3" x 3" 24 ga 304 SS with the end plates a little taller for the only two connectors.
The plates got stacked in a fixture with 1/8" balsa wood in between each one, and the sides got treated with a combination of GOOP marine down the bulk of the center, and FUSOR brand structural sheet metal epoxy along the top and bottom.  Slap on the sides and let 'er cure.
The whole thing is ~9" long, and I'm jes finishing up a containment vessel that will facilitate circulation of electrolyte, as well as provide a modicum of flash-back protection.   Still gotta test it.
Driving it with 120VDC [rectified wall mains], not over 15 amps for now.
Turtle, still building
« Last Edit: November 23, 2007, 03:18:01 am by keithturtle »
  • Pochin Hydrogen
  • Hydrogen to Drive
    • PochinTwin Hydrogen
« Reply #3 on: December 12, 2007, 17:43:24 pm »
I’m in the process of constructing my plate cells with an arrangement of +nn-nn+ a total of 70 plates
« Reply #4 on: December 12, 2007, 21:46:56 pm »
Hi,
Just a question. Why do you use 2 neutral plates? Did you run tests on how many are the right choice?
I am very curious about this, because I have tested neutral tubes in the past.
I also wanna make a plate cell.
What size plates do you advise?
Br
  • Pochin Hydrogen
  • Hydrogen to Drive
« Reply #5 on: December 12, 2007, 23:55:19 pm »
With the circuit I could use a single plate config. +-+-+ but I’ve seen more production of hho with the neutral plates I mite use a single neutral plate or just stick with the double neutrals. I’m using the plate cell just to get more area exposed; I know that I need at least 1.5 l/m of  the hho gas to run a small lawn more engine.
keithturtle
« Reply #6 on: January 03, 2008, 03:49:23 am »
The neutral plates act like a voltage divider.   If you have only three plates in a stack and apply 12 volts to only the ones on the ends and no wire to the middle plate, you will measure 6 volts between the center plate and the end.
Interestingly, that center plate takes on both a positive and negative charateristic, depending on which side you touch the probe to.   That be why we call it a NEUTRAL plate.   It will have the opposite charge than the charge applied to the end plate.
This design is referred to as a SERIES cell; alot like yer batteries stacked in yer big ol' D-cell flashlight.
It gives you flexibility with yer voltage sources.
Turtle
« Reply #7 on: January 03, 2008, 11:21:35 am »
Thank you, Keith
Thats why serie cell are fed by higher volts.
Can you tell us something about how many neutrals can be used, without use of chemicals?
I read that is not easy to to use many neutrals....
Can you also tells more about yr way of conditioning plates before use?
steve
