Author Topic: Coils mass amps restriction and applying e fields  (Read 11511 times)
« Reply #120 on: October 21, 2019, 03:50:21 am »
thats crazy! nice find!
« Reply #121 on: October 21, 2019, 06:02:55 am »
Interesting yes!
our resonant cavities are a sort of unidimensional for a frequency
those ball like cavities have a center frequency in 3 dimension
i think if we provide enough current there will be enough magnetic field to drive the cell into sort of sonic resonance... i think i hit it once as my cell started to sing but was 2,5khz pulsing dc into water straight from variac...
the magnetic field is of the current the electrode capture in its entire length but is concentrated on the electrical connector points since there forms the loop of most of the current so is like the cell have a toroidal magnetic field in the duct but not in longitudinal direction but around the electrode like it would do in a wire....
what is the magnetic field of a coax ? outside is zero right? well so somewhere it may interact
bucking fields are the base of john quincy st clair patents on wormhole and hydrogen generation! parenthesis
so the magnetic field plus the voltage applied will make a sound wave inside the cell! it will work itself like if it were a ultrasonic transducer and cavity all in one..
i think the water input and output may interfere on the cavity frequency
im thinking in the case of my cell the electrodes connector is one at the botton of the inner electrode and the other at the top of the tube so it may not have had the most of magnetic field cancelation! not sure its better or worst lets try again!!!!
at the time i used potassium hydroxide as electrolyte
« Reply #122 on: October 21, 2019, 09:59:39 am »
Its a nice video.
We learned again a bit more....
« Reply #123 on: October 21, 2019, 17:53:49 pm »
This video tells us that we can indeed use a light sensor to detect the resonance event
« Reply #124 on: October 21, 2019, 17:58:52 pm »
The spherical resonant cavity may be for the same reason!
Today im making new electrical connectors for the 11 cell... I believe i can make up to 1 liter per minute with it using the new connectors without spring
« Reply #125 on: October 22, 2019, 01:50:24 am »
I personally think the Forum should have a place set aside for Unique stuff that affects the water just passed this it's not every day we run across these types of equipment it would be very nice do you have a place dedicated just far anyting that alters the water in any way this way when we look at all of these devices we found that is 100% legit and prove Worthy we might gain more understanding about the water molecule. I myself I'm so interested and the post you have made here I am going to dedicate a folder on the hard drive of my laptop for unique situations just as you proposed here I am already doing this and several other situations and it is already giving me positive impacts on my research I just wish we could share a database like I am creating but everyone create it instead and everyone view it and use it I think it should be more of a factual section and if you wanted to talk about that specific item I guess that would be good too since each category is worth a same the unique category.
« Reply #126 on: October 22, 2019, 03:43:31 am »
Im not sure how but at the forum database there may br countless patents and docs and pics... Perhaps is possible to make a google drive like plataform
« Reply #127 on: October 22, 2019, 18:02:36 pm »
I'm interested in replicating the above video I would love to see a category here at this forum with unique cafex watch shown in the video above anything related to the water molecule I think should be in the category I believe that would help us understand the water molecule better and other molecules as well if we was to do this there's no telling what the small group here and ionization might be able to do in the future right now everyone's flat on their face that could do a 180 and I believe when this happens there will be a domino effect and we here my unlock I ton of stuff if we get our category straight. Stevie may I propose a new category? I feel as if the water molecule is worth it.
