Author Topic: Frequency,s for pulsed electrolysis known by me, till sofar  (Read 2123 times)
Re: Frequency,s for pulsed electrolysis known by me, till sofar
« Reply #16 on: September 08, 2019, 07:16:35 am »
More power is Produced than Consumed, For those that do not belive me, Ask stevie. Or shall I ask him here.
Stevie, I have a Question for you here.
Do you have to use an external Power Source to Produce hyrogen or electricity to the alternator? Or, can it be triggered without any external Power? Also, Remember back when We was Exciting the Roter with a battery just before we would Test this Theory. Could you tell the members here a little bit about what you remember?
« Reply #17 on: September 08, 2019, 07:25:42 am »
« Reply #18 on: September 08, 2019, 07:27:25 am »
For those that does not know,
« Reply #19 on: September 08, 2019, 08:06:30 am »
I have came to understand stan, when he states, you must use voltage to perform work, just as you would change the color on your tv, in other words, he is saying remove all contaminates from the water and use a Dc to Dc step up circuit to prove his theory. He was offered 250 million dollars to just stop his work.
« Reply #20 on: September 08, 2019, 11:51:51 am »
Just watch this.....
This is what you want to do, i think..
Its called a boost converter.
This guy is lighting a 12v led on a 1.5v battery.
The coil gets charged first and then the coil discharges, plus the 1.5v of the battery in series.
So shortly you get and power boost, so to say..
It is fun to build.
I once made one with a wfc,
I always wanted to go back to it again...
Remember that circuit we build that showed more power out then in?
Thats the other variant....
Charge the coil and cell, switch off and part of the bifcoil got its charge from the cell and then power on, double power to the cell....
With a low resistance watercell, you might need to add a second transistor. 1 extra after the diode. So, one that breaks the connection to the capacitor...when you switches on the other transistor for charging the coil.
« Reply #21 on: September 08, 2019, 11:54:50 am »
remember Pochintwin?
He replicated our circuit and he used a big bifilar toroid....
I have still all his data.
Like 350w in and like 500w into the cell
Or in his other video 60w in the circuit and 220watts out...in the cell....Brutal
« Last Edit: September 08, 2019, 12:15:34 pm by Steve »
« Reply #22 on: September 08, 2019, 19:50:39 pm »
can you post his circuit?
« Reply #23 on: September 08, 2019, 21:52:58 pm »
2 things are going on here, we use high amp draw like in your last post, and Stan explained you only need voltage. Both are acceptable in my book. But the alternator looks to be DC to DC.  And more power is produced than consumed if you do not include the driver moter.
