Author Topic: Cavitation!  (Read 6754 times)
Cavitation!
« on: May 12, 2008, 19:14:52 pm »
People are heating water with cavitation and animals are igniting water with it.
hydro
Re: Cavitation!
« Reply #1 on: May 12, 2008, 23:46:24 pm »
ok, i dont have the connection to view those videos, can you explain a bit in detail what cavitation is?
Re: Cavitation!
« Reply #2 on: May 13, 2008, 00:33:08 am »
I do not know enough about it to explain.
Find a way to watch the first video.
usuryfree
Re: Cavitation!
« Reply #3 on: May 19, 2008, 02:09:11 am »
carbedN,
[from my plumbing exp] cavitation is basically water molecule resonance in an enclosed space usualy created by a fast-acting valve, such as a washing machine's supply line cut-off valve.  This is also commonly known as "water hammer".  This affect can also be witnessed in supply lines not properly anchored (to code) and a simple kitchen or bathroom faucet.  What's interesting is:  the dude who discovered how to arrest "water hammer" ended up inventing the "hydrosonic pump"; which is supposedly 130+ % overunity.  Ironically, it is not the spring and baffle surrounded by a copper tube you buy at Home Depot to fix water hammer (which gets soldered on the end of a vertical -> horizontal supply junction).
Link to the hydrosonic pump:  http://www.hydrodynamics.com/technology_review.htm
there are also numberous youtube vids regarding the hydrosonic pump & its inventor.  If i remember correctly, the hydrosonic pump is one of the 3 inventions in the original "It runs on water" video, which of course, featured S.Meyer prominently.
The conspiracy theorist in me has noticed a pattern... whenever someone goes after big oil, auto, utilities - they get kilt, go missing, or otherwise cannot backup their claim.  However, if you remain benign to these entities, you get to remain in business.   To wit:  HydroDynamics inc.  and Hydrogen Application Technologies http://www.hytechapps.com.  It will be interesting (to me) to see what happens to the latter - since they say they are trying to adapt their "proprietary" generator to a car.  Note in that video though that they go to pains to say that even though they could run on 100% water - right now they are only doing a ~50-50 mix.
speaking of which - if i had 1/2 a ball, and 5K, i'd buy one of their "proprietary" generators - to take a look at the electronics... >:(
Re: Cavitation!
« Reply #4 on: May 19, 2008, 03:02:40 am »
Thanks for the insite, ufree.
I have seen the hydrosonic pump its a great device!
I think stan was using cavitation to further de-stablize the water molecule.
Here is the "resonant Cavity"
(http://i75.photobucket.com/albums/i283/carbednotch/Resonantcavity2.jpg)
And now the "Stacked cavity"
(http://i75.photobucket.com/albums/i283/carbednotch/StackedCavity.jpg)
Re: Cavitation!
« Reply #5 on: May 19, 2008, 03:06:08 am »
I think cavitation occurs in highly negative pressure zones. Which means when released from under pressure, the water would go from a high pressure zone to low pressure and if this action is done in an instant, the water implodes.
jbhuffinstuff
Re: Cavitation!
« Reply #6 on: May 19, 2008, 04:07:27 am »
the first picture that you show is a the lazer light cavity  the second one is a stack with hydrogen gas gun attached on top   if stan took to pieces of tin foil and attached it to a battery to him that was a vic circuit  he called everything that cause he has a sealed  patent on it so which  no one know whats in it
Re: Cavitation!
« Reply #7 on: May 19, 2008, 04:17:37 am »
I have Stan's patents on the VIC... Why do you say they are sealed and no one knows whats in it?
