Author Topic: Electrode comparison  (Read 3074 times)
Re: Electrode comparison
« Reply #8 on: November 26, 2018, 08:47:03 am »
is it not simply because the thicker the material the less electrical resistance. So the majority of the hydrogen ions will go preferable to the thicker negative electrode?
« Reply #9 on: November 26, 2018, 09:10:34 am »
when i think more about this, there might even be a potential difference between the two kathodes....
There must be, otherwise they would not act like this
« Reply #10 on: November 26, 2018, 15:07:02 pm »
i imagine that there is indeed...!
even if its very small would give this effect
if you want to see something even more strange isolate your system and apply high voltage to it as well in reference to ground or to the outside of your water tank...
there you will have ions
« Reply #11 on: November 26, 2018, 15:13:13 pm »
Drawing please....
« Reply #12 on: November 26, 2018, 15:17:08 pm »
i imagine the thinner electrode is maybe more negative.. but you could confirm that using a multimeter
« Reply #13 on: November 26, 2018, 15:38:09 pm »
here is a drawing of the situation i think is happening
thinking a little more about it the hydrogen itself may be charging the electrodes...
when you bubble hydrogen on a metal it get negatively charged..
this is pretty much the concept of a fuel cell.
« Last Edit: November 26, 2018, 16:29:35 pm by sebosfato »
« Reply #14 on: November 26, 2018, 17:29:38 pm »
If i remember, it might be the case that Kevin had an electromagnet around the bar that connects the two rond electrodes...
Then you have to deal with a magnetic field that attracks the hydrogen gas....
« Reply #15 on: November 26, 2018, 23:58:56 pm »
here is an idea
i forgot to add a capacitor at the ac line...
actually only a capacitor is needed on the ac line those L coils should not be there
