Author Topic: BOB BOYCE PLANS HERE!!!  (Read 21129 times)
Re: BOB BOYCE PLANS HERE!!!
« Reply #8 on: July 28, 2009, 12:12:00 pm »
An alternator produces a sine wave .
A sine wave is much smoother than pulsed dc , on the scope I can see that this rhytmic motion will do better than pulsed dc . It just makes sense that it would .
I have a 300W pure sine wave inverter and with the right plate spacing the gas output is extreme.
Have read that inverters can today have a efficiency up to 95% comparing the input and output.. but the energy in the HHO gas produced is at the moment unknown for me... Didn't Master Steve use a inverter for that motorbike idling?...Hmmm   ::)
Master Steve used 2 VIC's with blocking diodes and resonating chokes in where he got LC resonance and he busted water with 40Kv and 1mA, producing a massive 100ltres per second. ;)
But i just forgot how to replicate it.. :D
that's a sad thing.  ???
as always, it seems many people do have some good results but no other can replicate it because there are no good documents. and if there are good documents (like ravi) it does not work.
i'm intrigued by warps post but i never read something about 3500rpm, an alternator or that FQA30N40. It's probably because i did not read every post of every account he is using word for word, but if you could make like a document where you collect your knowledge, in a way that the others from this forum can understand and then replicate (i'm sure there would be enough people to try it), we could all get this working together. communication is really the problem, everyone is doing his own stuff, there is so much false information, and everyone would have to figure it out for himself, not to say most of the people at the waterfuelcell.org forum for example don't have any clue about electronics and mess things up more.
when the first step (getting more HHO energy than you put in via electricity) it's not important if you cannot run YOUR car on this immediately. there are plenty of options afterwards. (even stan ran only a lightweight dunebuggy with it)
« Reply #9 on: July 28, 2009, 16:04:53 pm »
You are correct Dankie.  By definition an "alternator" is an electric generator  that produces alternating current... ie. a sine wave.    But an "alternator based system"  can produce other wave forms as a result of adding other components.
"Resonance" is always in the form of a sine wave. So it could make  sense in certain applications to use a sine wave input .  Make a simple series LC resonant circuit and hit it with a sine wave at the resonant frequency and with a with a square wave at the resonant frequency. The sine wave will give greater gains given the same power input.   But .... square waves are easier to generate over a wide frequency range.
So,   are saying that applying a 120V AC   @ 2.5amps to a set of plates makes an extreme amount  of gas?   Are you sure that isn't steam?   ;D   Maybe you rectified it to DC first?
Please tell more.
Steve, when you remember.... I have a check for you for $50,000US for further development.
That's a sad thing.  ???
You said a lot there Haithar.
You  have to consider that SOME of those claiming to have good results may just be blowing smoke or seeking their 20 minutes of fame on Youtube.  (documents or not).  Some may not be.  But many times it's hard to tell which.
Also consider that,  many experimenters have no formal education or training  in how to do systematic and methodical  testing, note taking, etc.  It's same with technical writing skills (documentation).  Some have difficulty explaining  what they've done in terms that others can understand.
Then there are the "mean people" . These kind might have some knowledge,  but alienate others due to their pissy & arrogant attitudes.  These can't have an intelligent exchange of ideas with out ad hominem attack.  eg.  "If you  cant see what I'm saying (and agree with it) then,  you are an sub-moronic fool  and  have nothing to offer anyone ! "
Yeah Steve.  Mean people do suck.
3500 is the rpm/frequency that worked for Warp in his particular setup. The FQA30N40 is just a 400V 30 Amp  QFET from Fairchild Semiconductor . Nothing particularly magical about either one of them.  However,  If  someone wants to replicate what Warp did,  then they  will need to use exactly what he used.   If the RPM was 3500  then use 3500.  If the FET was a FQA30N40 then use that one.  If a tube was exactly 4.0 inches long by 1/2" diameter then don't use one that is 3.9 inches long by 5/8" diameter and expect it to work the same.
I sometimes wonder why there is so much focus on running a car with  HHO gas.  There are other more easily engineered applications.
Goey
« Last Edit: July 28, 2009, 16:32:07 pm by Goeytex »
« Reply #10 on: July 28, 2009, 17:43:56 pm »
Goey
Steam.... :D It was not steam...lol.. and yes, it was AC, but i had to have a adjust the plate gap ( bigger gap than with DC ) so the overload protection in the inverter didn't start to beep and shut itself down. AC can indeed make HHO.
I am thinking of getting me a 1000W inverter... really blow the water out of the bucket ;D
« Reply #11 on: July 28, 2009, 17:53:45 pm »
I have an idea on Master Steve's setup:
A 1:1 transformer, aka chokes, aka vic.
2 capacitors, one on each side of the transformer.
Isolated power supply for each half of the transformer and capacitor.
Use a stepup transformer to drive each half of the circuit.
Once in resonance, on each half, and 180 deg. out of phase from one another the current draw becomes low.
Add a diode for positive on one and negative from the other and connect to the water fuel cell.
The current will be low because of the isolated power supplies driving the circuit.
The water fuel cell will see the distributed capactance of the 1:1 transformer and allow that current to flow - which is very small in the overall schematic, yet be stressed by the high voltage potential of the steup up transformer.
Anyone with electronic experience can follow that and fill in the blanks, even point out some flaws I may have overlooked in this setup.
Anyhow that is my next project - still gathering equipment for this.
« Reply #12 on: July 28, 2009, 17:53:52 pm »
Goey
exactly my thoughts! My goal would be a stationary generator which creates electricity from water. With the smart grid coming and electric cars being able to drive several hundred miles per charge with a motor efficiency of >90% it's the best solution to me. also size and weight of your hho generator don't matter when you put it in a shack at your home.
Goey
in which way does this help? you are probably creating hydrogen with a really bad efficiency then, but what do you gonna need it for? if you are going to use more electricity than gas use an electric car.
« Reply #13 on: July 28, 2009, 18:24:08 pm »
Goey
Now .....tell me that the water did not get hot ......?
Did you take and record temperature measurements, current readings and voltage readings across the plates?
So ... why does my  Vicks Vaporizer make steam instead of gas?  All it is is 2 round carbon looking electrodes separated by a an inch or so with  120 Vac applied.   Current can be up to 6 amps or more depending upon the mineral content of the water.  Just boils the water.
Is there something you are not telling us?
Andrija Puharich used AC to make gas.  But he used Amplitude Modulation,  a special ceramic coating on the center electrode and a glass insulator between the electrodes.
Goey
« Reply #14 on: July 28, 2009, 18:25:31 pm »
I am just starting to remember........ ;)
« Reply #15 on: July 28, 2009, 18:30:17 pm »
Sounds good Warj. :)
Attached schematic is also providing a 180 out of phase volts vs amps..
http://www.geocities.com/SiliconValley/Pines/5440/supply.html
