Author Topic: Plasma Reactor Setup (GEET)  (Read 1038 times)
« on: August 28, 2018, 22:16:16 pm »
Hi All,
I'm going down the road with designing and building a GEET setup for testing and researching purposes. This project is a revisit from many years ago and with funds and design experience in hand, I feel like this is definitely doable.
For now, attached are PDFs and design snapshots for the overall setup. The test engine is a 5 HP Briggs and Stratton. I will be using a 3/8" diameter rod setup. I'm excited to see what happens.
Re: Plasma Reactor Setup (GEET)
« Reply #1 on: August 28, 2018, 22:23:35 pm »
Attached are some pictures of the overall build progress. From the initial design, I changed a few components to the fuel tank/bubbler system.
« Reply #2 on: August 29, 2018, 14:12:46 pm »
Nice one bro! compliments for the drawings and organization!
« Reply #3 on: August 30, 2018, 10:05:44 am »
looking good!
You will have a lot of fun!
« Reply #4 on: August 06, 2019, 02:23:47 am »
Hi All,
It's been a while. Here's the setup fully built. See the attached pictures. I'm able to get it to run on gas vapors.
I've made a few adjustments from the original design. Mainly from an assembly standpoint.
« Reply #5 on: August 06, 2019, 11:27:31 am »
are your bottles also freezing up when you run the system?
« Reply #6 on: August 06, 2019, 14:14:46 pm »
Yes. There is a definite temperature drop. The bubbler gets cold. I can pull -5 psi on the bubbler for a short while.
« Reply #7 on: August 06, 2019, 20:14:23 pm »
you should try to warm up the bottles...
This cold has a negative effect on running the geet engine
