Author Topic: The real test and development description of Stan Meyers voltage based system  (Read 3728 times)
  • Build it. Power it. Use it.
Where did you read draining part?
The last paragraph of Column 8 states:
The electron leakage resistor will again raise the upper limit of 8.5 volts amplitude before breakdown as shown at L-5 of FIG. 8. In the generation of the hydrogen and oxygen gasses to an infinite limit, as yet not fully appreciated, the upper level of amplitude of the voltage is removed with the utilization of the electron inhibitor of FIG. 7.
The two paragraphs above that are also relevant.
When he talks about electron leakage, he means from one plate to the other - through the water.  So this resistor is draining the electrons which would other wise flow through the cell. This resistor is shown as "60" in FIG. 6 and "75" in FIG. 7.  It's mentioned in the abstract, and in claim #33.
"The next circuit comprises an electron inhibitor that prevents the flow of electrons; the circuit being in the terminal line between the negative plate exciter and ground. In those applications of the generator wherein excessively high voltage is to be applied to the plate exciters for a very high yield of gasses, a second electron inhibitor of a unique structure is serially connected with the first electron inhibiter. The second named inhibiter having a relatively fixed value and the first inhibiter connected in series is variable to fine tune the circuits to eliminate current flow.""
That sounds familiair.........2 chokes? Maybe not needed?
Just as in Puharich it seems.
Do you care to post the patent number?
It is on 661 ended one
