Author Topic: Need your help!!!! I need the whole Herman Anderson Interview!!!  (Read 3616 times)
Re: Need your help!!!! I need the whole Herman Anderson Interview!!!
« Reply #8 on: May 22, 2019, 05:25:53 am »
Apparently those that have it are still believing its not worth it to share and sooo....its tainted ALOT of people from doing the same,which is fine everyone still has the chance to say they did it on ther own.
Its alot like stans in terms of resonance and as with Stans the inherent problems of  detecting and sustaining it is ther problem.
They havent figured it out yet is why they wont share it.
« Reply #9 on: May 22, 2019, 23:05:47 pm »
Yes. And tomorrow they die because of whatever reason and all knowledge is gone.....
SOOOOO SAD....
« Reply #10 on: April 11, 2021, 04:18:48 am »
« Reply #11 on: April 11, 2021, 08:46:00 am »
Thanks Jim,
This explanation is taken out of the big video above. Its at the end if that.
Its all about radiolysis of the hho.
The wraps around the cell of wire where the spark power is traveling thru, is also creating a magnetic field to accelerate the ions in the cell.
Those two factors should create deuterium from H....
More mass more energy
« Reply #12 on: April 16, 2021, 08:35:57 am »
I think his secret was the space between his  thin layer of elecltrode under is anode bolt head power connection was  part of his " Ion King" experience.
When Bob scoped that cigar box circuit he said it put out 15 hertz that was split into 7.5 on and 7.5 off times.
Herman refferenced a patent that put out the waveform he used.
He stated in his interview a continuous wave keeps on operating and amplifies the current akin to the way a lead crystal does.
https://patents.google.com/patent/US6119651A/en
https://patents.google.com/patent/US4820957A/en
« Last Edit: April 16, 2021, 09:14:38 am by Ks »
