Author Topic: My Herman Anderson replication project  (Read 42710 times)
« Reply #144 on: December 20, 2018, 22:22:08 pm »
Herman is a combination of Horvath, Puharich and Dyer is the best way i can explain it.
You should build Puharich's circuit and get this waveform...Hermans is the same .Once you understand how to produce the resonance you can move further to produce a certain resonance....
After you study Puharich and build the circuit and understand how its produced you can move on to Horvath to understand the certain resonance you want.Horvath teaches us what we want know about the magnetic parts.
After you learn and know that you should study Dyer and learn how to apply it.
Thats as plain and specific as I can be with that.
« Reply #145 on: December 21, 2018, 14:10:40 pm »
Dyer? Who ,s that?
« Reply #146 on: December 22, 2018, 19:49:36 pm »
C.K.Dyer
You will learn why waveforms are important.
Itsa barrier technology combined with atomic resonance  is a good way to see it in my book.
« Last Edit: December 23, 2018, 03:50:57 am by NewGuy »
  • Build it. Power it. Use it.
« Reply #147 on: December 23, 2018, 15:57:25 pm »
I found a patent which claims that NMR frequencies can produce catalysis without using a physical catalyst.
« Reply #148 on: December 23, 2018, 18:19:07 pm »
I searched for c.k.dyer but found only electrolysis info on anodes and kathodes...
If you have any docs, then plse publishe here....
As far as atomic resonance concerns, what shall i understand from that?
With NMR, you need a hugh magnetic field, otherwise that hydrogen cannot be detected..
« Reply #149 on: December 28, 2018, 22:53:11 pm »
3 inch = 7.62 cm
Thats the space between the 2 electrodes of Andersons cell.
Now the funny part..... He is pulsing at 7.5hz or close to that frequency......could be 7.6hz
What could be the relation here?
Anybody?
« Reply #150 on: December 28, 2018, 23:52:46 pm »
I think he may have used relays at that frequency ... Im not sure but seems a happy coincidence
« Reply #151 on: December 29, 2018, 06:28:45 am »
3 inch = 7.62 cm
Anybody?
Youre not seeing whats inside those 7.5 cycles.
Thats like me saying i pulse this at 7.5 cycles.
Where this is an inverted sawtooth hermans was a square. It reminds you of Stans gated pulse but instead of it being a forced oscillation....its a natural thing and by natural i mean its a resonate thing.
Here's the funny part...whats inside that 7.5 cycle is a corona frequency that just so happens to match a requirement related to the magnetic field the atoms are entrained in.That magnetic field requirement is directly effected by the potential hydrogen in the chamber.
Theres a reason for that....theres a reason for why a 2 close proximity wont let anything happen....theres a reason for that reason and so on.
Merry Christmas  :)
« Last Edit: December 29, 2018, 07:09:59 am by NewGuy »
