Author Topic: Horvath seem to have inspired meyer in many ways...  (Read 9893 times)
Re: Horvath seem to have inspired meyer in many ways...
« Reply #16 on: February 18, 2016, 20:51:26 pm »
Have you seen his waveforms yet?
« Reply #17 on: February 18, 2016, 22:23:20 pm »
has anyone had a look at fig 1 circuit diagram of Horvath patent then look at the component list ?
« Reply #18 on: February 18, 2016, 22:47:43 pm »
No. Not seen any waveforms.....
« Reply #19 on: February 18, 2016, 22:48:03 pm »
Tell me.....
« Reply #20 on: February 18, 2016, 23:04:58 pm »
I have this circuit on paper with D11 citcled for some reason...it seems like such a huge circuit mayb to much for me
Is it worth noting it states Horvath Systems produced 1.45 lpm?
« Last Edit: February 19, 2016, 00:35:58 am by KS »
« Reply #21 on: February 19, 2016, 01:48:08 am »
if anyones gonna go through the patent , list or diagram (3 different things)
time constant = R1 x C2 ,    2.7k ohm x .1uf  , freq is calculated from that
Ive made push pull transformers before and nothing like that diagram.
R9 is 5watt and R10 is 1 watt , these are for the transistor bases !
Z coil is centre tapped and secondary coil is centre tapped , thing is line 29 and 33 are negative earth , D1 and D2 are reverse , they can only conduct is the centre tap line 31 is negative in comparison to line 33 ... but SCR is connected to line 29 , which is negative also .
SCR anode is connected to the centre tap ?  theres no connection to the positive rail for the SCR
the winding ratio isnt 18:1 , the Tr2 doesnt have a rectifier , cathode 13 is definitely negative earth but that doesnt count as a rectifier
has anyone else looked over the circuit diagram ?
« Reply #22 on: February 19, 2016, 05:30:56 am »
I remember a question about him never answered as well....he says his radiation part later on was at the bottom.... akin to a Bingo Fuel fuel reactor but space much farther apart and only one electrode radisted at a time...is this what his radiating elements were but instead of 36 volts..30,000 volts....some how current i inhibiting?
« Last Edit: February 19, 2016, 12:25:25 pm by KS »
« Reply #23 on: February 20, 2016, 02:47:00 am »
The cannadian patent really seem more complete and he talks about his principle of operation...
he indeed say he uses radiolysis in combination with electrolysis telling that radiolysis change the faraday relation between product and charge run thu circuit...
in my opinion the energy radiolysis provide is traped into the resonant cavity until it dissipate so it affect many molecules time after time..
