Author Topic: cheap alternator hack  (Read 5980 times)
jrmalin
Re: cheap alternator hack
« Reply #8 on: May 04, 2008, 06:43:07 am »
Here's the mount, a little bit of unistrut a 1/3hp electric motor 1725 rpm,  some bolts and weld it up!
  • OO-Rah!
« Reply #9 on: May 04, 2008, 08:51:21 am »
JRMALIN
It look good, But you may want to start looking for a bigger motor.
Here is my experience was an under powered motor.
View Profile Email Personal Message (Online)
Re: Spikes Cell
« Reply #26 on: March 20, 2008, 11:09:30 PM »
   Reply with quote Modify message Remove message
Alternator update
GM 40 amp Alternator, 1/2 hp 1750 rpm 8.7 amp motor
All on tap water, no additives, no circuit, with a 3" pulley on the alternator
3" pulley on motor, with 1 amp 12vdc power supply to rotor= 200cc/min
4" pulley on motor, with 1 amp 12vdc power supply to rotor= Alternator overheating
4" pulley on motor, running wire from stator to rotor=120cc/min
5" pulley on motor, with 1 amp 12vdc power supply to rotor= motor amped out
5" pulley on motor, running wire from stator to rotor= 175cc/min
back to 3" pulley on motor, with 1 amp 12vdc power supply to rotor.
need 1 hp motor next.
And get parts to build hydros circuit to pulse rotor.
Spike
Let us know how it goes
Spike
Tommy
« Reply #10 on: May 04, 2008, 13:46:15 pm »
JR,
Great little series there. Thanks for taking the time to break that all down and post pictures. I'm sure that will help many people just starting out with this.
I also agree with Spike. You're going to need a bit more power when you start testing.
