Author Topic: Water Quality  (Read 1815 times)
Water Quality
« on: February 25, 2015, 06:43:49 am »
Do NOT use chlorinated water on your tubes.  Chlorine is highly reactive and will create an oxide on your pipes even thou stainless steel.  This will royally mess up your cell capacitance as the oxides will cause a higher capacitance than what you may be factoring for.
Re: Water Quality
« Reply #1 on: February 25, 2015, 22:26:33 pm »
thnks for the tip.
I always remove the water after a test....
Helps too
Re: Water Quality
« Reply #2 on: March 01, 2015, 00:53:07 am »
"No conventional dielectric material could prevent charge carrier breakthrough. In a double-layer capacitor the chemical stability of the solvent's molecular bonds prevents breakthrough"
« Last Edit: March 08, 2015, 10:08:35 am by geon »
