Author Topic: Complete VIC Circuit- but couldnt work? :(  (Read 5709 times)
« on: October 12, 2014, 00:20:16 am »
Hi everyone,
 I have a problem. please help me. I download and built   from
« Last Edit: October 12, 2014, 12:56:52 pm by hgul »
Re: Complete VIC Circuit- but couldnt work? :(
« Reply #1 on: October 12, 2014, 17:38:12 pm »
Hi everyone,
« Reply #2 on: October 12, 2014, 20:27:43 pm »
Hi everyone,
Dear Hgul,
Thanks for showing yr setup.
For years now people are trying to replicate Stans work.
But no succes yet.
Did you ask Tony for help?
« Reply #3 on: October 12, 2014, 21:32:34 pm »
Thanks for your answer Steve. yes  I asked and mailed to Tony , and waiting for answer. :-[
« Reply #4 on: October 12, 2014, 21:43:30 pm »
Maybe we can help if you make a schematic of your setup.
How does yr VIC looks like?
How many turns per coil, wire thickness and winding directions, etc etc?
I seen on Tony,s documents that he had some ideas of his own, which where not the real vic setup of Meyer.
cheers
« Reply #5 on: October 12, 2014, 21:54:54 pm »
thanks for your help Steve. I usede Tony circuit from his website
http://www.globalkast.com/documentation.htm
http://www.globalkast.com/docs/VIC_Transformer_&_Cavity.pdf
http://www.globalkast.com/docs/VIC_Circuit_Production_Eagle-5.10.0_Files.zip
I make all of them how written in schematic . working on nearly 2,5 months :(
« Reply #6 on: October 13, 2014, 20:20:07 pm »
If i remember correctly, the two choke and their connections are not hooked up well.
All coils must be wind in the same direction as well.
My 2 cents is to start slowly with 2 volts on the primary, see if you can find resonance and then tune up.
Also use a 70 ohm resistor over the primary...
For now that what i know...
« Reply #7 on: October 15, 2014, 21:27:58 pm »
Hello Steve,
im doing many tests too here.. no results...
i think theres something on the winding of the chokes that can makes its resonant frequency lower somehow.. mine are resonating at 30khz or so.. i used insulation between each layer...
i get the step charging i guess... but no bubbles at all...
Welcome hgul keep strong.. its kind of a hard way to get it done... i think you better get the cell like meyer or steve did and start testing.. .it simply wont come out of of nothing! Believe-me... we are into this since many years.. .
if we can help you in anyway let us know.... as steve said try show the schematics of your coils..
Good luck!
