Author Topic: new cell  (Read 6996 times)
new cell
« on: September 11, 2014, 14:50:17 pm »
This is my new cell... all hand made..
« Last Edit: September 11, 2014, 15:16:43 pm by sebosfato »
Re: new cell
« Reply #1 on: September 11, 2014, 15:04:29 pm »
i made a 1 liter reservoir in the top 10x 10x10 cm and its leaking because when i pushed the screws the resin that i used to glue it didm´t supported... i´m going to apply neutral silicone to fix that for the moment... it happens because plexiglass can bend and the resine cracks if bent...  its the only flaw however in the design,,,
« Last Edit: September 11, 2014, 21:59:32 pm by sebosfato »
Re: new cell
« Reply #2 on: September 12, 2014, 04:11:59 am »
I think the neutral silicone solved! thanks mookie..
I spend much less to do this version ... than the delrin case one..
Re: new cell
« Reply #3 on: September 12, 2014, 08:20:24 am »
Well done. It looks impressive :-)
You are some steps ahead on my cells :-(
Re: new cell
« Reply #4 on: September 12, 2014, 14:36:18 pm »
Steve was very easy to do.. almost al the holes i did on my hand machitta driller and the holes for the electrodes was made with the still driller..
i got a xy table and made out of my still driller a kind of low precision milling machine.. that worked well for plastic..
you just need the tools and the drill bits.. =) and sand paper to get the plastic back alive ... the electrical connection i made with allen screw and a screw pressed into it.
now with the foots looks like a spaceship
« Last Edit: September 12, 2014, 14:52:28 pm by sebosfato »
Re: new cell
« Reply #5 on: September 13, 2014, 09:09:41 am »
Well, if it works then it works  :)
Fab, did you got the cores i send you?
Re: new cell
« Reply #6 on: September 13, 2014, 12:09:14 pm »
they are still at Shipment at customs since 29 august... according to the tracking...
« Last Edit: September 15, 2014, 13:42:05 pm by sebosfato »
Re: new cell
« Reply #7 on: September 13, 2014, 12:17:11 pm »
thats odd....
Maybe they drilled the cores in seRch for dope... :)
