Author Topic: The VIC with resonant cavity project by Steve..  (Read 104417 times)
« Reply #216 on: February 23, 2016, 10:13:16 am »
No problem, kevin.
« Reply #217 on: February 23, 2016, 10:14:10 am »
My drinking water specs are:
pH 8.33
154 PPM
Is this good or bad for a Meyer system?
Anybody?
« Reply #218 on: February 23, 2016, 11:17:54 am »
When i cook the water and cool the vapours down , i have around 30 PPM.....
« Reply #219 on: February 23, 2016, 18:26:41 pm »
Hey Mr,
Your water is little harder than mine here i have tap water at 90ppm and using a filter i can bring to 0ppm
not sure if  is good for meyer..
i´m planning to close the holes of my cells such to have greater isolation between tube sets...
« Reply #220 on: February 23, 2016, 20:24:50 pm »
So, i now measured the output of the secondairy coil in my VIC.
I got a nice sinewave out of it at 25khz.
Output voltage unloaded, just my scopeprobe: 200VAC at 12Vdc inout till 600VAC at 31Vdc.
Fabio, when i remove the diode from across the primary, i get a little bit more output on the secondairy, without disrupting the sinewave.
I also took a little gap between the two core parts of about 5mm. That helped out as well.
I now have to modify 1 capacitor in my PWM, as the 25khz is almost as high as it goes now. Small modification, but needed.
So, i can understand that Meyer used a 600V diode as VIC diode with his setup!!!!!
Now, up to my chokes. Will start with equal lenghts, as my 4 cell waterfuelcell in series should be also equal in metal surface....
Cheers
« Reply #221 on: February 23, 2016, 20:51:18 pm »
Same output volts here Steve,without the diode across the primary.With the diode it kills it at 130v max.
« Reply #222 on: February 23, 2016, 21:35:08 pm »
Thanks Adys!
Good to know.
Here a scopeshot..
« Reply #223 on: February 23, 2016, 23:37:58 pm »
most meyer diagrams shows nothing but the switch.. but you are all right to try all ways man..
i´m finishing some projects now and keepon testing!!!
i was considering if having capacitors in parallel with the cell woudnt create an alternate path for the force...
