Author Topic: The VIC with resonant cavity project by Steve..  (Read 83627 times)
« Reply #176 on: July 26, 2015, 04:56:42 am »
A couple more Pics
« Reply #177 on: August 24, 2015, 22:53:04 pm »
smelly solder iron...hmmmm
burning fingertips....aiai
progress.....
« Reply #178 on: August 25, 2015, 00:40:14 am »
whats that bro?
« Reply #179 on: August 25, 2015, 09:38:03 am »
After 8 years of testing and experimenting, i found a way to produce highly ionized oxygen and hydrogen by use of this secret electronic steering device.
When you have the proper electrodes in your cell with specific size and distance, working in a soft pressurized environment, tuned into resonance of the watermolecule, you can see an anomaly.
That special state produces litres of hho per minute, you never have seen before.
The gas is also not the same as from electrolysis cells.
A test in a lab provided that outcome.
Maybe i will make a video of the setup.
Not sure yet if i want to share the totall technology as open source.
I want to market this solution towards all the ends of the world. Make a better place for my children.
« Reply #180 on: August 25, 2015, 11:32:40 am »
congratulations Steve
i waited for this,
i just took a deep breath...
i hope you decide what its better for the technology! I have my opinions and you know that already so i will only respect hope we can work on together on this whatever your choice is!
Im very happy now..
by the way i googled it but i found only things related to car... what is a steering device?
« Last Edit: August 25, 2015, 11:58:50 am by sebosfato »
« Reply #181 on: August 25, 2015, 14:39:01 pm »
Hope is not the trick day in your country  8)
« Reply #182 on: August 25, 2015, 15:34:43 pm »
I just took some words that i rememberd from the many fails claims........Made a shiny story out of it....
Its just the pwm of electrojolt that i am building......
« Reply #183 on: August 25, 2015, 16:16:09 pm »
Oh man let it shine
i'm doing some work here...  on the feedback... i found that its getting 90degree dephased when get the resonance at the coil on the vic.. thats why its getting it off from resonance... but what is so strange is that there should not be 90 degrees there... what cause it? do you know how can i change a signal phase? maybe with opamps?
its little hard to go with only two channel old oscilloscope.. to see all this i have to use the multimeter too so i can see if resonance peak arrived...
i also noticed the false lock in conditions that should be avoided... i believe... i would be when the pll locks to the subharmonics
for example my coil 700turns resonate at 40khz it will lock at 63khz and at 22khz  it will lock at the last if i turn off the voltage and climb up again...
reverting the feedback it dont lock to sub..
