Author Topic: The VIC with resonant cavity project by Steve..  (Read 104371 times)
« Reply #112 on: March 30, 2015, 07:48:01 am »
Bingo. 3 coils down. 1 choke to go...
Steve, so this has been a while and you had 1 choke to go.
What has happened?
Hahahahaha........ Good question.
Well, the last choke is half way finished.
Its all by hand and i want each winding to be perfect.
Any progress from your project? Still building ?
Cheers
« Reply #113 on: March 31, 2015, 02:25:24 am »
Yes still working away at it.
Long time ago purchased a full pgen from Gunther, had problems with software.
Figured that all out and it works great.
Although the pgen is controlled by the computer it takes a while to dial in, like when you have potentiometers its much more quick.
Then figured out how to pulse the positive side.
Hooked up many SCR's and played with them, then looking through my old electron components found one just like Meyers and date code was from the 80's.
Made a huge SCR pulse on its own without a pulser, it filled the choke with so many cycles from the DC fullwave rectifier and then turned off by itself.
Found that this had to do with resistance to the gate.
When connected to an opto it would not work because there was too much resistance in the opto.
Then started to use the Meyer SCR and it worked.
Can break any water but nothing fantastic. But current is lower and gas is milky cloud style.
Made a little test cell again but much better this time for those experiments.
Started to play with choke size MH when doing these experiments, so its working good at basically around 40 to 65 mh.
Tried 120mh it would not work, tried 90mh it would not work so when it got down to 65mh it started working. Adjusted to around 54-56mh
Also I noticed if the choke was not connected right it would not work. Only works in one direction.
Now I connected a transformer I made with tiny wire and 10 tap primary, feeding into a set of chokes made with multi-fillar of tiny wire.
It makes gas, but have not seen a resonant signal yet, that's where I left off waiting for the weather to warm again.
So I'll be back at it here as the garage is getting warmer again.
But I'm very curious as I know you will do a great job on your setup here.
« Reply #114 on: April 05, 2015, 05:07:48 am »
Steve, Coils look great... I have a update to share...I been working on the Laser accelerator and laser distributor. Here are a few photos.
« Reply #115 on: April 06, 2015, 21:47:46 pm »
Hi Ron,
I never seen anybody replicating the distributor of Meyer before.  Nice work!!
« Reply #116 on: April 07, 2015, 00:10:00 am »
No need to replicate it without a working cell.
« Reply #117 on: April 07, 2015, 02:45:59 am »
@ Steve, we have been busy replicating Stan's complete Gms Unit and Vic Unit along with everything else.
@ outlawstc, Do you think I would be spending all this money on Stan's complete Gms unit and Vic unit if I didn't have a working cell? I think not, It sure isn't for show and tell. I stopped spending money on show and tell along time ago.
Got the extended shaft made for it today. All that is left to do on it is cut it to the right length. I should finish all of it this week.
« Last Edit: April 07, 2015, 04:23:18 am by R.Walker »
« Reply #118 on: April 07, 2015, 10:42:56 am »
Thats a lot of work you have done and need to do, Ron.
looking forward to the rest.. ;-)
« Reply #119 on: April 10, 2015, 02:49:09 am »
Power Supply and Accelerator Board arrived today. Got the Led's and sensors in the accelerator board finally.
« Last Edit: April 11, 2015, 13:56:09 pm by R.Walker »
