Author Topic: VIC pictures and Don's VIC notes..  (Read 16661 times)
Re: VIC pictures and Don's VIC notes..
« Reply #8 on: July 27, 2014, 23:29:42 pm »
Got one more shot, after tuning my coils a little more today, I got the full potential out of my VIC. Been running now fro over an hour now and everything is still running cold coils, transistors, ect. I think I will quit while I'm ahead. LOL
Ron,
What kind of core are you using?
Can i buy it somewhere?
« Reply #9 on: July 28, 2014, 00:22:06 am »
« Reply #11 on: July 28, 2014, 08:25:45 am »
Sure can, http://www.aliexpress.com/snapshot/231356182.html
Thanks Ron.
The shape is different then the Meyer cores.
Is this the one you use with primary, secondairy, chokes and measure coils?
cheers
« Reply #12 on: July 28, 2014, 11:40:34 am »
I use a little different concept than Stan did, but still does the same thing. I put two coils on one set of cores and two coils on another set of cores.
« Reply #13 on: July 28, 2014, 11:47:42 am »
Thanks R.Walker,
I was trying to do that messing up with the coupling but is much harder...
Incredible
could you explain a little about what you believe is the effect of using this bucking fields?
Just another silly question... the size of the cell matters? I mean you can get the same effect on the 9 tube cell and at the resonant cavity setup with the same trafo setup? just varying the signal frequency and voltage level of both transformers?
Of course i´m assuming you are using two transformers to adjust the relation between the voltages in the secondary and chokes separately
I´m sure you drank the same water we did =)
regard that the saying in this drawing is:
5) Secondary coil winding (8 ) resonant charging chokes (9/12) of similar size and length sets up "Electron Bounce " zone by which the displaced electrons forms copper ions moving and taking on a positive electrical charge entering into resonant charging choke (9); Whereas, the clustering of electrons at resonant charging choke (12) forms negative voltage polarity of opposite electrical polarity intensity.
« Last Edit: July 28, 2014, 16:17:26 pm by sebosfato »
« Reply #14 on: July 28, 2014, 19:48:38 pm »
Ok, Ron.
The 2 core sets are not hooked up to eachother?
Stacked on top of each other?
Cheers!
« Reply #15 on: July 28, 2014, 19:54:20 pm »
Thanks R.Walker,
Incredible
He, Fabio,
Electron bouncing now finally creates a picture in my brain........ yes the gray thing existing from 2 cells in my head....
