Author Topic: Stanley Meyer Index to Figures by Number in Stan Meyer ETM Book  (Read 1885 times)
One  problem for researchers of the Meyer technolgies has been the  lack of a comprehensive index
to the figures in the various  publications. The following is a work in progress that lists the figure by number and
reference:  Thanks to GNPTrust for permission to create and post an index to their upcoming ETM book
(Most of the page references work for Dealership Sales Manual 1986 edition) ETM is a later or expanded version)+
INDEX TO FIGURES
Figure 1      Energy Gap        ETM C4
Figure 2      Electrical Polarization of Water
Figure 3      Utilizing Voltage Potential to Split the Water Molecule
Figure 4      Electrical Polarization of the Water Molecules Occurs in All Natural Waters\
Figure 5      Voltage Potential Performs Work without Amp Flow                                              ETM  E3
Figure 7      Dissociation of the Water Molecule is Directly Related to Applied Voltage            ETM  E6
Figure 8      Geometrical shape of the Voltage Zones Alters Hygrogen Gas Yield                    ETM  E7
Figure 9      Voltage Intensifier Circuit        ETM  E8
Figure 9A    Variable Pulse-Voltage Frequency RestrictsAmps While Controlling Gas Yield       ETM  E9
Figure 9B    Variable Amplitude Unipolar pulse Voltage Frequency Superimposed onto 50%
                   Duty cycle Puse train dynamically contro;dd the hydrogen gas rate while
                   restricting amp flow        ETM  E10
Figure 9BB  Applied Voltage to Plates        ETM   E11
Figure 9C    Variable Gas-Rate Control Circuit
Figure 9D    Voltage Chamber        ETM  E13
Figure 9E    Voltage Chambers in Stacked Arrangements                                                         ETM  E14
Variable Voltage Pulsing Circuit  (VVPC)
Figure 9XA      Variable Voltage Pulsing Circuit Schematic                                                      ETM   E33
Figure 9XAA    Variable Voltage Pulsing Circuits Componet Wiring Harness                            ETM   E34
Figure 9XAA1  Voltage Intensifier Assembly        ETM   E35
Figure 9XAA2  Variable Voltage Pulsing Circuits Printed Circuit Board                                     ETM   E36
Figure 9XAA3  Variable Voltage Pulsing Circuits Component Layout                                        ETM   E37
Figure 9XAA4  Variable Voltage Pulsing Circuits Wiring Harness                                             ETM   E38
Variable Pulse Voltage Frequency Generator (VPVF)
Figure 9XB     Variable Pulse Voltage Frequency Generator                                                      ETM  E39
Figure 9XBB  Variable Pulse Voltage Frequency Generator Printed Circuit Board                     ETM   E40
Figure 9XBB2 Variable Pulse Voltage Frequency Generator Wiring Harness                             ETM   E42
Variable  Gate
Figure 9XC     Variable Gate Circuit Schematic        ETM   E43
Figure 9XCC   Variable Gate Printed Circuit Board        ETM   E44
Figure 9XCC1 Variable Gate Component Layout        ETM   E45
Figure 9XCC2 Variable Gate Wiring Harness        ETM   E46
 Voltage Regulator
Figure 9XD     Voltage Regulator Circuit Schematic        ETM   E47
Figure 9XDD   Voltage Regulated Printed Circuit Board                                                          ETM   E48
Figure 9XDD1 Voltage Regulated Component Layout                                                             ETM   E49
Figure 9XDD2 Volage Regulator Wiring Harness        ETM    E50
Sequential Gate
Figure 9XE      Sequential Gate Crk't Schematic        ETM    E51
Figure 9XEE    Sequential Gate Printd Crk't Board        ETM    E52
Figure 9XEE1   Sequential Gate Component Layout                                                              ETM    E53
Figure 9XEE2  Sequential Gate Wiring Harness        ETM    E54
Figure 9xA/E    Cage Wiring Harness        ETM    E55
Figure 9XF      Toroidal Voltage Intensifier Circuit Schmatic                                                   ETM    E56
Figure 9XG      Rotary Volage Intensifier Circuit Schematic                                                   ETM    E57
Figure 10         Hydrogent Gas-Yield is Also Related to Planar-size of Voltage Zones            ETM   E15
Figure 12         Electrical Voltage Zones(B-B+) Forming a Resonant Cavity                           ETM   F2
Figure 13         Longitudinal Resonant Cavity        ETM   F3
Figure 14         Spherical Resonant Cavity        ETM   F3
Figure 15         Spherical Rasonant Cavity        ETM   F4
Figure 16         Variable Voltage Amplitude Controls Resonant-Action Output                      ETM   F5
Figure 16A       Applied Voltage to Resonant Cavity                                                            ETM   F6
Figure 17         Resonant-Cavities Forming the Water Vessel                                            ETM   F9
Figure 18         Photon energy Aids Resonant Action                                                         ETM    F10
Figure 19         Laser Injected Resonant Cavity        ETM    F11
Figure 20C      Resonant Cavity Dual-Voltage Pulsing Cavity Circuit                                 ETM    F16
Figure 20D       Power Load Disribution        ETM    F17
Figure 20E       Controlled Energy-Yield from Water Atoms                                                ETM    G2
Figure 20F       Hydrogen Fracturing Process        ETM    G3
Figure 20FA     Hydrogen Fracturing Process Prior to Gas Ignition                                    ETM    G4
Figure 20FB
Figure 20FC     Optical Thermal Lens Assembly        ETM  G6
Figure 20G       Gas Resonant Cavity        ETM   G7
Figure 20H       Gas Inector Fuel Cell        ETM   G8
Figure 20JX     Gas Resonant Cavity        ETM   G29
Figure 20YBB  Variable Pulse Voltage Wiring Harness                                                        ETM  F29
Figure 20YC    Variable AlternateSwitching Gate Circuite Schematic                                   ETM  F30
Figure 20YCC   Variable Gate Wiring Harness        ETM   F31
Figure 20YD     Gate Driver Circuit        ETM   F32
Figure 20YDD Gate Driver Printed Circuit Board                                           ETM  F33
Figure 20YDD1  Cascaded Gate Switch Printed Circuit Board                      ETM  F34
Figure 20YE     Variable Sequentila Gate Circuit to Resonate Cavity Array
                         Circuit        ETM   F36
Figure 20YEE  Sequential Gate Printed Crk't Board                                        ETM   F36
Figure 20YEE1 Variable Sequential Gate Component Layout                          ETM   F37
Figure 20YEE2 Variable Sequential Gate Wirign Harness                               ETM  F38
Figure 20YF      Voltage Regulator Circuit Schematic                                      ETM  F39
Figure 20YFF    Voltage Regulator Wiring Harness                                        ETM   F40
Figure 20YG    Voltage Intensifier Circuit Schematic (Resonant Cavity)         ETM  F41
Figure 20YH    Rotary Voltage Intesnsifier Circuit Schematic (resonant Cavity)  ETM  F42
Figure 20YJ  Photon or Light Injector Module Schematic                               ETM   F43
Figure 20YJJ   Light Injector Module Assembly                                             ETM   F44
Figure 20YJJ1   Light Injector Module Printed Circuit Board                          ETM   F45
Figure 20YJJ2   Light Injector Module Component Layout                             ETM   F46
Figure 20YJJ3  Variable Pulse Voltage Wiring Harness                                 ETM  F47
Figure 20YA/J  Cage wiring Harness                                                             ETM  F48
Figure 20YI      Voltage Level Switching Printed Crk't Board                          ETM   G34
Figure 20YIA    Gas Resonant Cavity Schematic                                          ETM   G35
Figure 20YIB    Voltage Level Switching Component Level Layout                ETM   G36
Figure 20YIC    Voltage Level Switching Wiring Harness                               ETM   G37
Figure 20YID    Electron Extractor Grid                                                         ETM   G39
Figure 20YIE    Electron Extraction Schematic                                              ETM   G40
Figure 20YJJ1  Light Injector Module Printed Crk't Board                              ETM    F45
Figure 20Z/C     Cage Wiring Harness                                                          ETM    G23
Figure 22         Water Fuel Cell Retrofitted to an Internal Combustion Engine  ETM  H4
Figure 23         Types of Land Vehicle Fuels                                                   ETM    H5
Figure 24         Rendering Hydrogen Safer than Natural Gas                           ETM    H6
Figure 24SA     Catalytic Block Assembly                                                        ETM    H13
Figure 24SB     Quenching Nozzle        ETM    H14
Figure 24SC     Recycling Flame Gases                                                         ETM    H15
Figure 24SD     Preventing Gas Ignition                                                          ETM    H16
Figure 25          Quenching Tube Allows Hydrogen to be Distributed without Spark Ignition    ETM  H7
Figure 26        EPG Principle Allowing Permanently Magnetized Fluid
                       Medium to pass though a pickup Coil                                      ETM    J4
Figure 26A        Attenuating Gas Field                                                           ETM    J5
Figure 26B        Pickup Coil Configurations                                                   ETM    J6
Figure 26C       Multi-Tier EPG Electrical Generator                                      ETM    J7
Figure 26D       Electomagnetic Pump Assewmbly EPG                                ETM    J8
Figure 26E       Electromagnetic Pump Assembly (EPG)Electronic Schematic and Component Layout
Figure 26F       Rotating Magnetic Fields without Mechanical Displacement
Figure 26ZA     Opposing Magnetic Fields                                                        ETM  J32
Figure 27 EPG Mechanical Drive Gas Accelerator                                          ETM   J12
Figure 28           EPG Electrical Magnetic Gas Accelerator                              ETM   J13
Figure 29           EPG Photon Drive Accelerator                                              ETM   J14
Figure 30           EPG Magnetic Field Spin Generator                                      ETM   J15
Figure 30ZC      Magnetic Spin Generator (Quiescent State}                          ETM    J37
Figure 30ZD      Magnetic Spin Generator (Triggered State)                           ETM    J38
Figure 32QX     Steam Resonator Schematic                                                 ETM     K21
Figure 37          Internal Combustion Electrical Generator                              ETM     K12
Exhibit AZ
Exhibit E1              Variable Spacing                                                              ETM     E58
Exhibit Photo EA1  Variable Plate Spacing Test Unit                                      ETM     E59
Exhibit E2              Tubular Cluster-Array                                                       ETM     E60
Exhibit Photo E2a  Cluster Array Test Unit                                                     ETM    E61
Exhibit Photo E3    Electrical Polarization Process                                        ETM     E62
Exhibit E4              Longitudinal Resonant-Cavity                                          ETM     F49
Exhibit Photo E9    Multi-Tier Resonat Cavity Assembly                                ETM     F56
Exhibit E5              Spherical Resonant Cavity                                              ETM     F51
Exhipt Photo ZX    EPG Mechanical Drive Assembly                                     ETM     J33
Exhibit Photo ZY   EPG Electomagnetics Pump Assembly                             ETM     J33
« Last Edit: April 09, 2014, 05:06:57 am by jim miller »
Re: Stanley Meyer Index to Figures by Number in ETM Book
« Reply #1 on: April 06, 2014, 09:48:35 am »
good job, Jim.
Maby we can adjust thuis forum a bit to match your list......
« Last Edit: June 27, 2015, 15:58:40 pm by jim miller »
