Author Topic: Resonant Action (the Resonant choke system) Explained  (Read 10073 times)
Re: Resonant Action (the Resonant choke system) Explained
« Reply #8 on: March 07, 2014, 05:14:27 am »
I think is the best theory i designed i the last years
Please comments are desired to start this discussion.
Have started trying?
« Reply #9 on: March 07, 2014, 08:37:37 am »
Meyer refer to resonant action explaining that is all about movement and deflection of the ions...
I worked this days with many concepts of magnetism and some new exiting experiments that are keeping me from sleep and simply i decided to think about the resonant action stan proposed again..
I was thinking about what if we could simply create a high voltage strong field but instead of pulsing it and its than switched off and reverse the polarity in a ballistic manner to collide the ions and electrons in the bath.
The idea is:
choke connected in series to a dc source  a secondary of a transformer and the cell, the primary is wound facing the secondary and this is pulsed in such a manner that the pulse sums to the dc during pulses on an rapid enough completely reverse the polarity of the cell shooting the ions back into the water as the magnetic field collapses ... as the ions cannot go fast enough they get ionized and the electrons should create an avalanche like effect.
So basically you are applying Dc and a Pulsed current at the same time...
Switching polarity while hitting high voltage is how the "Super Heated Steam Generator" "produces steam with converting the water into the gases."
Hyper speed friction makes steam.
jp
« Reply #10 on: March 07, 2014, 12:18:05 pm »
Th steam resonator should be te same but he probably switch the polarity before the gas is released from the reaction...
« Reply #11 on: March 07, 2014, 22:15:40 pm »
Yes, just clarifying...next step is "Electron entrapment/recycle back to input = monotomic H H O
JP
« Reply #12 on: March 08, 2014, 01:55:05 am »
Heres how i see it
(http://www.ionizationx.com/index.php?action=dlattach;topic=2855.0;attach=13365;image)
« Reply #13 on: March 08, 2014, 06:44:03 am »
Heres how i see it
Yes, like whiplash...
jp
« Reply #14 on: March 08, 2014, 13:31:44 pm »
Heres how i see it
jp
Notice that Vo situation to Vn situation vary with duty cycle applied to the transformer. the wave form is not going to be like that but the Vn is the level between the positive pulse and the negative pulse. (the zero level)
« Reply #15 on: March 09, 2014, 09:26:28 am »
Heres how i see it
jp
Stan just called it "step charging."
