Author Topic: 5 toroid generator  (Read 3890 times)
5 toroid generator
« on: February 21, 2014, 01:57:31 am »
Following the spirit of the electrical pulse generator patent i found that maybe if toroids are arranged in geometric proportions the same principle could be applied with no moving parts
The idea is that toroids contain the field inside it but outside it there might be some kind of electric field... the idea is to cause induction on the output coil but having no reaction of the output coil to the input coils thereto if this coils were arranged in a resonant setup lots of energy could be generated...
The T1,,3,4,are primary coils the T5 is the output coil..
(http://www.ionizationx.com/index.php?action=dlattach;topic=2847.0;attach=13293;image)
Re: 5 toroid generator
« Reply #1 on: February 21, 2014, 15:26:17 pm »
I'm saying that i used the same principle that i identified in the Electrical Pulse Generator patent from Stan, because the output coil is just the same.
But instead of needing for movement it uses varying magnetic flux of resonant driven circuit.
The main diference is that its not going to be able to generate Dc current...
« Reply #2 on: February 21, 2014, 22:01:34 pm »
what if you can fake the motional emf , em field propagation is finite isnt it?  :P instead of moving the magnet move the em field..
« Reply #3 on: February 21, 2014, 23:23:21 pm »
Thats the spirit...
good idea... do you know how could that be done?
« Reply #4 on: February 22, 2014, 02:07:20 am »
I have so many ideas and no time and energy to make them and see if they work or not...
« Reply #5 on: February 22, 2014, 07:01:01 am »
no but I'm guessing with an LC lattice
« Last Edit: February 22, 2014, 07:18:38 am by geon »
« Reply #6 on: February 22, 2014, 08:52:52 am »
share your ideas you can see if they work in theory.
« Last Edit: February 22, 2014, 20:48:07 pm by geon »
« Reply #7 on: February 23, 2014, 06:24:04 am »
It would be a cleaver way i guess.
good idea!
I'm sharing a lot this thought..
Your drawing is the same as mine but your drawing shows the falling of magnetic fields when the current in the primaries are in the same direction of the secondary.
« Last Edit: February 23, 2014, 06:41:04 am by sebosfato »
